7.3 connecting rods - Page 2 - Ford Truck Enthusiasts Forums
7.3 connecting rods
Old 01-28-2012, 09:05 AM
2006lariat's Avatar
2006lariat 2006lariat is offline
2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation
Look at the rod's, if they are the older forged rod's they will have a line all the way around the rod. Forged rod's also have nut's on the stud's.
The later forged rod's (Sinter Forge) are smoother with no "cast" lines. The PMR FORGED rod's will have a bolt.
There are pictures in the link included elsewhere in this thread.
Old 01-28-2012, 09:31 AM
2006lariat's Avatar
"[quote=cleatus12r;10559242]I guess I may elaborate a little more.
I wouldn't call one process more "refined" than another. The forging process is a good bit different, but what happens to the connecting rod AFTER forging is quite different.
The "forged" rods are cast as two pieces. The main beam is produced separately from the cap of the "big end". The two halves of the big end are mated together (using a machining process), the rod bolts installed and torqued, the bore is machined, and then honed. At this point, the cap and the rod are a matched set. Then it's back apart to install in the engine. While it is possible to bolt another rod's cap on any of the other rods (and there will be little to no indication that it is incorrect), it is very possible to end up with journal clearances that are too tight, too loose, or just a bit off-center. The "forged" rods take a lot more machining to be correctly fit to a crankshaft journal."
The Forged Rod's are Forged all at once. The Crank end in most cases was Oval, and had to have the "straights" machined off, to make the hole round, than put together and honed.
Old 01-28-2012, 11:50 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Quote:
Originally Posted by cleatus12r View Post
making of a 5/16" square drive tool.
I found that a nail punch I had was a perfect 5/16" square.
Fits the inspection hole plug perfectly.
Old 01-28-2012, 04:23 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
7.3 DIT Connecting Rods:
Dates:
Forged Rods: 1994-2000
PMR Rods: 2001-2003
Engine Serial Numbers:
Forged Rods: 501 - 1,425,746
PMR Rods: 1,425,747 - 2,030,402
Part Numbers:
Forged Rods: F4TZ-6V200-CARM
PMR Rods: 1C3Z-6200-AARM
1994 F350 crew, shortened frame, w a 93 Cummins, NV4500, gear vendors and NP205 JacoFordCummins Engine Swaps 40 02-21-2017 10:18 AM
Connecting Rod recomendation. juancho_uy Ford Inline Six, 200, 250, 4.9L / 300 11 11-19-2015 08:12 PM
95 f150 5.0 with 1.7 rollers? does it have forged pistons? Anthonynoble 1987 - 1996 F150 & Larger F-Series Trucks 6 07-14-2015 09:43 PM
THESE Rods: Forged or PMR??? ToMang07 1999 - 2003 7.3L Power Stroke Diesel 3 01-30-2012 08:24 AM
400 Connecting Rods for sale slim pickens 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 7 09-24-2007 12:17 PM
Tags
1999, 2000, 73, connecting, diesel, f250, ford, forged, installation, kit, metal, powdered, rod, rods, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
