2001 7.3 Powerstroke diesel (block drain plug) - Ford Truck Enthusiasts Forums
Old 07-10-2011, 10:42 AM
SD Rick SD Rick is offline
SD Rick is starting off with a positive reputation.
Hey Peeps .
I want to drain my coolant fully,and do a complete flush and coolant change on my 2001 F250 with Powerstroke diesel.
To get the cleanest and most complete draining of the system,I'd like to drain the block,after draining the system at the radiator and hoses.
From the picture provided,can you tell me which of these two drain plugs is for the coolant?
Thanks in advance !
Rick
Old 07-10-2011, 12:52 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 07-10-2011, 01:01 PM
Farmboypowerstroke Farmboypowerstroke is offline
Farmboypowerstroke is starting off with a positive reputation.
The bottom one is a return to the oil pan, so not that one
Old 07-10-2011, 01:44 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
Here is the one on the drivers side. There is also one above the starter on passanger side. Make sure you disconnect the batteries or you might get some fireworks. Don't ask me how I know....lol..
Ford Truck Enthusiasts Forums - tdpower's Album: Useful pics - Picture
Old 07-10-2011, 02:53 PM
td,
Well.... You could not have made it any plainer that that !
Excellent description and illustration.
Very well done !
Thank you very much !
Rick
Old 07-10-2011, 08:48 PM
Krazymaan Krazymaan is offline
Krazymaan is gaining momentum as a positive member of FTE.
Why wouldn't you just put a T in the heater core line and flush it with the garden hose. the thermostat isn't going to stop the block antifreeze from coming out. It'll come out. Quick too
Old 07-11-2011, 09:17 AM
SGnAZ's Avatar
SGnAZ SGnAZ is offline
SGnAZ has a very good reputation on FTE.SGnAZ has a very good reputation on FTE.SGnAZ has a very good reputation on FTE.
Here is the procedure I used.
Ford Super Duty Coolant Flushing Procedure | Superdutypsd.com
This is by far,the best write up I've seen on the subject.
Old 07-11-2011, 09:51 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
That's a good write-up Steve.
He has a bunch of good write-ups.
Superdutypsd.com Write-up Index
Old 07-11-2011, 09:03 PM
I cannot begin to tell you how impressed I am with the content on this forum and especially with the willingness of it's members to help !!!
When I have the chance to reciprocate ,I will definately do so!
Thank you very much!
Rick
Old 07-12-2011, 03:05 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
This one is better! http://www.ford-trucks.com/forums/96...ml#post8935201
Same author (Gooch) but it's an FTE thread!
Stewart
Old 07-12-2011, 08:14 AM
SGnAZ's Avatar
Stewart
Right you are
1995 F250 Powerstroke 7.3 Collant Drain Plug Michael Law 1987 - 1996 F150 & Larger F-Series Trucks 0 02-01-2017 04:00 PM
How To: Flushing with Restore and Restore Plus 99ExpyProblems 6.0L Power Stroke Diesel 18 05-17-2016 01:29 PM
Block drain Q Deluxe06 1999 - 2003 7.3L Power Stroke Diesel 8 04-11-2014 12:13 PM
Draining ALL coolant from Aerostar? DMTR Aerostar 31 01-31-2014 06:31 PM
coolant drain plugs? eric3t 1978 - 1996 Big Bronco 3 06-14-2002 08:02 PM
Tags
2001, 73, block, coolant, diesel, drain, draining, f250, flush, ford, plug, plugs, powerstroke, radiator, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
