Go Back   Ford Truck Enthusiasts Forums > Marketplace > Want to Buy > WTB - Parts & other
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
  #1 (permalink)
Old 07-10-2011, 09:17 AM
Southern Buckers's Avatar
Southern Buckers Southern Buckers is offline
Garage is empty, add now
Southern Buckers is starting off with a positive reputation.
straight front axle and rear axle to fit 1997 F-250
I am wanting to put a straight axle under my 1997 crew cab F-250 and get rid of my TTb. I am also looking for a rear axle as well. All F-350 if possible. I am also looking for SD springs that are "V" code as well. Thanks for any help!
  #2 (permalink)
Old 07-23-2011, 12:45 PM
Wreckmaster's Avatar
Wreckmaster Wreckmaster is offline
Wreckmaster is starting off with a positive reputation.
You're looking for a Dana 60 for the front with a drivers side drop. They're a bit pricey in case you haven't noticed. The rear will be a Dana 60, 70 or a sterling 10.25"/10.50" They're pretty cheap.
What do you mean by the SD springs that are "V" coded? I may have em from a 92 F-250 (2WD) diesel that I'm parting out... How would I tell by looking at them?
  #3 (permalink)
Old 07-27-2011, 11:26 PM
gearfather gearfather is offline
gearfather is starting off with a positive reputation.
axles
Quote:
i have a matching set from a 2003 f350 srw dana 60 front and 10.50" rear. 3.73 ratio. i also have some brand new 10.5" 4.30 posi rears rotor to rotor...
  #4 (permalink)
Old 07-28-2011, 12:37 PM
I am looking for a '78-'79 or a late eighties to '92 model dana 60 front axle. You will have to look in some of the older posts under 1994.5-1997 power stroke diesel forum to tell you how to know if they are "V" coded springs. I think it tells you in the door jamb or glove box.
Not interested in a newer body style axle as they will not fit right up to my truck.
I am looking for a 4.10 gear ratio also.
  #5 (permalink)
Old 08-04-2011, 03:50 AM
jerg_064's Avatar
jerg_064 jerg_064 is offline
jerg_064 is starting off with a positive reputation.
I have a 88 pair I just put up.
http://www.ford-trucks.com/forums/10...0-25-rear.html
No stock springs though.
__________________
James
2003 F350XL SRW SCLB 6.0 4x4 ZF6
  #6 (permalink)
Old 08-04-2011, 04:24 AM
fatdan460's Avatar
fatdan460 fatdan460 is offline
1985 american sex machine
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
i'm bored, just to clear some stuff up, 77.5-79 d60 fronts aren't a bolt in for an 80-97 truck.
85.5-97 d60 front's will bolt in just fine. you stated specific years so i'm assuming you want a kingpin axle, really no advantage over ball joints for a truck on 38's or smaller tires. and bj axles generally run a little cheaper.
99-04 s/d d60's will bolt in fine, but then you need new metric pattern wheels.
super duty v code springs are leaf springs, the guy with a 2wd 92 f250 would have coil springs because it's 2x.
your current rear end doesn't need replacing unless it's a 3.55 geared axle and you are swapping to 4.10's. it's a full float sterling 10.25 and.....
you'd need a sterling rear (88ish and newer 10.25 or 10.50)either way for the speed sensor abs crap tone ring junk.
p.s. jerg_064, unless those axles were special order gears from factory new it's either 3.55's or 4.10's. i've yet to see an 85-97 f350 4x4 with any other gears stock.
not trying to be mean, just clearing some stuff up and broadening your options
__________________
Quote:
Originally Posted by alpha/omega View Post
His brain wouldnt function under what you would call "normal" conditions. Dan is truely one of a kind. Too weird to live and too rare to die.
your post per day average may be 2.03 but your lols per day far exceed any one else on FTE hands down.
  #7 (permalink)
Old 08-04-2011, 07:08 AM
Thanks fatdan! I am just learning as I go while trying to find some of these parts. I have read a lot of posts about this but they seem to run together so that is why I have my dates all mixed up. I will not be running anything 38's or over on this truck. Thanks again!
  #8 (permalink)
Old 08-04-2011, 11:22 AM
jerg_064's Avatar
Quote:
Yea, your right. They're 4.10s
__________________
James
Tags
1997, 250, 4x4, 97, axel, axle, end, f250, fits, ford, front, modle, rear, rebuilding, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
