Dana 60 axle shafts broke
Old 07-10-2011, 12:37 AM
arkredneck's Avatar
arkredneck
arkredneck is offline
So I mud raced the truck with the 52" tires and broke the inner and outer axle shafts on the Dana 60 and lost the u joints so y'all got any ideas how to rebuild it better
Old 07-10-2011, 06:46 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Fullcrew7.3 is offline
Rockwells. I think with the gearing you've got and the really tall tires, the D60 may not stand up well to too much abuse. Other than that, Chrome moly 35 spline shafts.
Here's for the u-joint and outer shafts.
Dana 60 35 Spline Upgrade Kit
https://www.4wdfactory.com/store/pro...D-Locking-Hubs
Not sure what to say about the inner shafts. They are not usually the part that breaks.
Old 07-10-2011, 06:52 AM
427 fordman's Avatar
427 fordman
427 fordman is online now
Yep, you're gonna keep breaking 60 parts with them tires, Rockwells are your friend.
Old 07-10-2011, 10:02 AM
arkredneck's Avatar
arkredneck
What broke is the ears on the shafts where the u joint sits I would rather not go Rockwell cuz I don't think it will be streetable then
Old 07-10-2011, 10:55 AM
Fullcrew7.3
In that case a stock replacement inner shaft should work. I really don't know of any upgrades for that. The 35 spline outer shaft is a pretty common upgrade for the D60.
Old 07-10-2011, 11:12 AM
arkredneck's Avatar
arkredneck
I've seen the 35 spline outers and chrome moly I'm just wondering if the chrome molys ears are stronger since I broke both inner and outer ears on both axles
Old 07-10-2011, 11:49 AM
Fullcrew7.3
I would assume so, but I couldn't tell you for sure. You could check on the 4x4 forum. There's a few guys there that have done it. They're not quite as friendly there, so watch your step.
Old 07-10-2011, 12:59 PM
Epd444's Avatar
Epd444
Epd444 is offline
I would definitly do the chromemolys along with re gear
Buddy of mine has an 01 F350 with 54'' tires, i forget his gearing but its 5.something and he bogs the thing all the time with not too many issues.
Old 07-10-2011, 03:11 PM
arkredneck's Avatar
arkredneck
I know it needs re geared but that shouldn't affect axle shafts breaking should it
Old 07-10-2011, 05:45 PM
rodneywar's Avatar
rodneywar
rodneywar is offline
the ears are breaking off cause of the immense torque required to turn the 52s while bogging. with cromoly axles you probably will break them as well maybe not on the first run but it will get stressed out then break.
Old 07-10-2011, 06:01 PM
arkredneck's Avatar
arkredneck
So who makes the best axles with the best warranty?
Old 07-10-2011, 11:57 PM
BuckHammer's Avatar
BuckHammer
BuckHammer is offline
Lol, you consider 52" tires streetable? What do your streets look like?
Old 07-11-2011, 12:14 AM
Muktown's Avatar
Muktown
Muktown is offline
Haha I was thinking the same thing. Definitely not legal here not to mention you probably need hydraulic steering which also isn't legal. Just curious but how would stronger axles make it not streetable?
Old 07-11-2011, 06:57 AM
Fullcrew7.3
I know those tires wouldn't be legal here, but some would use them until they got caught. My 37's are already pushing the legal limit.
Old 07-11-2011, 07:07 AM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
lol no kidding. rockwells are the only option unless you dont wanna play. you gotta pay to play.
cromo's are stronger but not THAT much stronger. friend of mine broke cromo D60 shafts running 44's. granted he was into the stupid pedal, but thats kind of the point. i run cromo's in my bronco but only run 39's and feel very confident.
-cutts-
