vacuum switches - Ford Truck Enthusiasts Forums
vacuum switches
Old 07-09-2011, 11:30 PM
johaner78 johaner78 is offline
johaner78 is starting off with a positive reputation.
vacuum switches
on the original 400's, there was a couple vacuum switches mounted into the thermostat housing. I think one of them was for the vacuum advance to the distributor - is this correct? And if so, is it necessary to use this thermal vacuum switch for the distributor vacuum advance or can the vacuum advance be tied directly into the carb base?
Old 07-10-2011, 05:19 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
There are myriad different types of these valves.
One each one is a raised ovate section, has an ID engineering prefix/suffix marked on it, post what they are.
Similar to this: D7AE-A1A
Old 07-10-2011, 08:45 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
Not a 400 guy, but the ones linked to distributor vacuum I've ran across, kept vacuum advance from working till engine reached a certain temp.
Old 07-10-2011, 11:13 AM
bamaf150's Avatar
bamaf150 bamaf150 is offline
bamaf150 is gaining momentum as a positive member of FTE.
I had one out of the T stat housing yesterday, threads were bad so I took it to an autoparts store to find a tap and the switchs are still available , fyi
Old 07-31-2011, 09:17 AM
Bill - Numberdummy (or others): i found the vacuum switches finally lol One is a Brown color with ID D7AE-B1A and the other one is yellow color marked D7AE-A1A. Both are 3 port switches. My question is: do I need either of these for the vacuum advance on a Duraspark II distributor or will the distributor not really care if I have a vacuum switch installed in the vacuum advance line that goes from the carburetor to the distributor? If I need one of them, which one and how do i connect the vacuum lines? I see there is a port marked with a - symbol.
Old 07-31-2011, 11:05 AM
psquare7575's Avatar
psquare7575 psquare7575 is offline
psquare7575 is starting off with a positive reputation.
The color is indicative of the activation temperature of the switch.
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
The three-port switch is for the vacuum advance; it switches out manifold vacuum vs. ported vacuum to the vacuum advance based on temperature. In my experience, you can safely forgo this switch and connect the advance directly to the spark port (passenger side on the base). Obviously it would be better to stick with the factory configuration, but from what I have seen, you can get by without it assuming your initial timing is set high enough.
A two-port switch is typically used to cut off the vacuum source to the EGR valve under a certain temperature, and if you have an EGR system then you do need this switch - and if you originally had an EGR system then you do need an EGR system.
Old 08-08-2011, 03:27 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
Although you can hook the vacuum advance up directly to ported vacuum at the carburetor without any problems, the vacuum switch on the thermostat housing does serve a useful function.
The switch on mine is red, and it has 3 marked ports - 1, D, and 2. Port "D" is where the distributor connects to. Port "1" connects to ported vacuum at the carburetor, and Port "2" connects to manifold vacuum at the vacuum tree on the back of the intake manifold.
This switch is rated for 225 degrees, meaning the engine uses Port "1" (ported vacuum) under normal conditions. However, if the engine begins to approach 225 degrees, this switch will cut off Port "1" and turn on Port "2" to give the engine full manifold advance. What this does is speed the engine idle up, which in turn speeds up the water pump, which helps to cool your engine off faster. Once the engine is cooler than 225 degrees, the switch returns to the normal Port "1" again.
Old 08-08-2011, 07:34 PM
lariat85 - thanks for that detailed explanation, I'll keep this for reference for sure. For right now I've put in plugs into the thermostat housing where these vacuum switches go. If I have troubles with timing when engine is cold vs. hot, I'll put in the red switch I have and follow your directions.
Thanks again!
2150A - No Distributor Vacuum Port Codeseven Fuel Injection, Carburetion & Fuel System 3 07-05-2016 03:41 PM
Ported Vacuum Switch for Vacuum Advance? Ford59galaxie 1973 - 1979 F-100 & Larger F-Series Trucks 21 02-12-2016 06:29 PM
vacuum/egr help needed Oldbone 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-07-2012 05:05 PM
Venturi Vacuum and Vacuum Advance Superred2 Ford Inline Six, 200, 250, 4.9L / 300 5 12-15-2010 12:43 PM
2 vacuum port distributor question ? ADSf100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 03-21-2003 11:53 AM
Tags
351m, d7aea1a, d7aeb1a, ford, ford400keepthermostathousingvacuumvalve, forum, manifold, port, ports, spark, switch, themistat, thermostat, vacum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
