HELP With A Ford 460 ECM Computer - Ford Truck Enthusiasts Forums
Old 07-09-2011, 11:12 PM
kennyr kennyr is offline
kennyr is starting off with a positive reputation.
I own a 1992 Fleetwood Pace Arrow(class A) RV. Just recently the engine would not turn over. I drive it about every other month, so the RV was sitting for about a couple of months. I had a mechanic(35yrs. experience) look at it and it check the fuel pump(inside the gas tank) and it was NOT running.When he hooked up a direct hot wire to the pump, it was working...I replaced the fuel filter a week before the problems and the mechanic checked the fuel injectors and there was no fuel going to the injectors. He put ether in the intake, and the engine temporary started and died, so he determined it was not the ingitation module. So he determined it was the ECM computer. I found a company in Houston who could rebuild the computer and I shipped it off. They called me and said the ECM had already been rebuilt and could not be done again. I found out that the previous owner took it in for the recall #94b37 in 1994, so that might be the time it was rebuilt. So the Houston company found me another ECM with the correct numbers and it was shipped out. Installed the ECM...same problem, it will not start. I went to the Ford dealer and they said they could program the ECM I just bought, but they need the old ECM to get info off of it. Well, the company in Houston, AUTO AND HEAVY DUTY COMPUTER SUPPLY does NOT answer their phone nor do the return emails messages. When I bought the new ECM, I requested that they return the old ECM and I would pay shipping. So....the problem I have...how do I get the new ECM programmed with the correct settings. Ford says they need the old ECM to program the new ECM...and if this Houston company does not return my old ECM, I am in trouble...any suggestions?...I am leaving on a family trip in 10 days, so I need HELP right away. Here are the stats on my RV:
1992 Fleetwood Pace Arrow 33ft.
ECM # F29F-12A650-ANA
Ford 460 7.5L
4 Speed Automatic Overdrive Transmission
Old 07-09-2011, 11:49 PM
Nealcrenshaw's Avatar
Nealcrenshaw Nealcrenshaw is offline
Nealcrenshaw is starting off with a positive reputation.
Not sure why ford said they need the old ecm,they can program the new unit.
Old 07-10-2011, 12:25 AM
That is what the parts guy said...I am suppose to talk to the service manager on Monday and he is the one that programs the ECM...I sure hope YOUR right...or maybe find another 92 Fleetwood Pace Arrow owner with the same engine/trans and get all the info...I will let you know on Monday..thanks
ECM Swap - Drivability LittlePete 6.0L Power Stroke Diesel 5 10-07-2016 01:25 PM
1998 Ranger ECM failure, again and again Help Please antiqueynot Ranger & B-Series 25 04-17-2012 12:31 PM
I need the ECM calibration code of the THE BLUE HEAP 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 03-19-2012 08:29 PM
1992 bronco 5.0 injectors not working will2045 1978 - 1996 Big Bronco 17 01-31-2012 04:12 PM
ECM Engine Computer HELP! kennyr Computer Chips & Tuners 11 07-11-2011 11:30 AM
Tags
1992, 2003, 460, 75, arrow, ecm, f250, fleetwood, ford, fuel, pace, program, pump, taurus, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
