4R100 or 4R70W
4R100 or 4R70W
2001 150 Lariat VIN # 1FTRW08L51KE66887
What transmission would be in this truck ?
how many bolt are in the 4R100 transmission pan
how many bolts are in the 4R70W transmission pan
Thanks
Thanks
on
The certification label on the drivers door jamb will show which transmission was originally included in the truck.
20 bolts 4R100
E code on label
14 bolts 4R70W
U code on label
on
works now that you corrected the VIN
1FTRW08L51KE66887
Primary Features
Minor Features
Primary Features
Build Date: 29.08.2000
Vehicle Line: F150
Body Style: Double Cab (3/4 Door)
Version: 150
Engine: 5.4L Modular SOHC V8
Transmission: 4R70W (AODE) 4-Speed Auto Trans
Drive: LHD 4WD (PTD)
Axle Ratio: 3.55
Emission: California Emission Requirements
Air Conditioning: Manual Air Conditioning
Territory: (+)"USA"
Paint: Oxford White
Vehicle Line: F150
Version: 150
Axle Ratio: 3.55
Territory: (+)"USA"
Paint: Oxford White
Minor Features
- Medium Parchment
- Less RH Side Loading Door
- Less LH Side Loading Door
- With Tailgate Lock
- Less Second Unit Body Covers
- With Pick-Up Tie Hook - Inner
- With Pickup Box Extender
- Less Load Box Bedliner
- With Base Payload Package
- 139"/3531MM Wheelbase
- XLT
- Lariat
- Less Fleet Related Items
- Kansas City Plant Build
- U.S. Sales
- Security Lock Group
- Less Special Equipment Package
- With Convenience Group
- Less Exterior Dress Up Package
- 6750 LB. GVW
- Less Appearance Group
- XLT Sales Badge
- With Premium Equipment
- Less Exterior Appearance Pack
- With Power Equipment Group
- With On-Board Diagnostic System
- Less Special Language Label
- Owner Hand Book Pack
- Less Mass Customization Package
- With Power Front Windows
- Less Rear Quarter Window
- With Privacy Glass
- With Sliding Rear Window
- Standard Ovrhed Console & With Rail
- Less Floor Mounted Console
- Adjustable Accl/Brake Foot Pedals
- Front Floor Carpet Mats
- Rear Floor Carpet Mats
- With Carpet Floor Covering
- With Cloth Headlining
- With Illuminated Sunvisor - Drivers
- With Illuminated Sunvisor-Passenger
- Less Running Boards
- With Painted Front Grille
- With Accent Wheel Lip Moulding
- With Lower Body Moulding
- Less Side Auxiliary Step
- With Dipping Rear View Mirror
- Drivers C/K Power Mirror
- Passenger Power Mirror
- With Body Coloured Exterior Mirror
- With Signal Mirror System
- Less Adhesive Mirror Backing
- Front Seat Armrest/Stowage
- Less Temp Control Driver Seat
- Less Temp Control Passengers Seat
- With 2nd Row Bench Seat - 3 Passngr
- With Driver 6 Way Pwr.Seat Adjuster
- With Heavy Duty Trailer Towing
- With Front Towing Hook
- Less Engine Oil Cooler
- Double Cab (3/4 Door)
- With Central Locking System
- With Door Entry Remote Control Unit
- With Keyless Entry System
- Less Sun Roof
- Rocker Tu-Tone Paint
- Front Bumper - Steel Chromed
- Rear Bumper - Steel Step - Chromed
- With Front Licence Plate Bracket
- Less Seat Integrated Restraint
- With Driver Air Bag
- With Passenger Air Bag
- With Frame Mounted Tyre Carrier
- Spare Wheel-17" Alloy Style 2
- H/D Dual Front Shock Absorbers
- Heavy Duty Rear Shock Absorbers
- 7.5 X 17" Styled Steel Wheel
- P265/70R 17 A/T OWL
- With Conventional Spare Tyre
- With Super Engine Cooling System
- Less Immersion Heater
- With Standard Suspension
- 3.55
- Rear Axle Limited Slip Differential
- 3800 LB(1724 KG) Rear Axle Assy
- 5.4L Modular SOHC V8
- With 4 Wheel Disc-Brake
- 4 Wheel Anti-Lock Braking System
- With Standard Transmissn Oil Cooler
- With Electric Shift
- With Skid Plates
- With Single Fuel Tank
- Less Auxiliary Fuel Tank
- For Unleaded Fuel
- Less Gaseous Prep Pack
- With Tilt Steering Wheel
- Leather Steering Wheel
- With Speed Control
- With Conventional Instrumentation
- With MPH/KMH Speedometer
- With Tachometer
- Less Anti-Theft Alarm
- Heavy Duty Battery
- Elect Premium AM/FM Stereo/Cass/Clk
- Less Radio Pre-Equipment Pack
- With CD Player Autochanger
- With NAAO Radio Frequency
- Less Family Entertainment System
- Less Travel Note Message System
- Less Homelink
- Less Daytime Running Lamps
- With Front Fog Lamps
- With Illuminated Entry
- Engine Compartment Light
- With Dual Beam Dome Map Light
- With Load Compartment Lamp
- With Automatic Headlamp On/Off
- Arizona Beige
- Oxford White
- 150 Series
- Less B&A Control Codes Issue 030388
- With Overspeed Warning Disabled
- 4R70W (AODE) 4-Speed Auto Trans
- F150
- (-)"CDN"
- (-)"BRN"
- (-)"CHL"
02 Super Duty Guy
1999 to 2016 Super Duty
06-20-2013 09:40 AM
