Testing Coil Pack 5.4l - Page 2 - Ford Truck Enthusiasts Forums
Old 12-02-2004, 02:35 PM
FHI-prez FHI-prez is offline
FHI-prez is starting off with a positive reputation.
I also had a coil pack fail last year. It ran like crap, and couldn't find the problem, but I just kept running the begger until it threw a code. Finally, it threw #5 coil as being the culprit. Sometimes like stated above the computer won't throw a code until the misfire is sufficient enough to cause a trouble code to be shown.
You can also test the emission system by puttin a vacuum pump on the EGR valve and pumping the EGR valve open when the engine is running at idle. This should kill the engine. If it does not, then you have to pull the plenum and clean it out as deposits can get in there and clog it up. This is of course assuming that you know the EGR valve is operating correctly, as well as your DFPE sensor and vacuum control module for the EGR valve. All of which are easily bench tested to see if they are in good operating condition. Eventually this too would throw a "recirculating exhaust gas flow excessive detected", Code #P0402.
Nick
Old 12-02-2004, 07:51 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
my dads o2 e150 has a similar problem, it said that it was #3 so we swapped the pack and plug with #8 and it still says #3. so maybe a fuel injector?
Old 08-30-2010, 01:48 PM
Rg1Baja's Avatar
Rg1Baja Rg1Baja is offline
Rg1Baja is starting off with a positive reputation.
Sweet Ive joined the club of people who have washed their 5.4L. But thanks for the info. Helped greatly.
2004 5.4 ignition coil packs no1moonman 2004 - 2008 F150 2 01-10-2014 11:20 AM
Coil Pack Moisture rrichmon Modular V8 (4.6L, 5.4L) 13 04-24-2013 11:39 AM
Coil pack instead of COP'S SteevenH 1997 - 2003 F150 7 12-05-2012 08:33 PM
coil packs bcompton35603 Expedition & Navigator 7 12-10-2009 03:31 PM
Napa Coil Packs - Any good? warmdye Modular V8 (4.6L, 5.4L) 3 11-30-2004 03:23 PM
Tags
54, 54l, bench, check, codes, coil, cop, ford, pack, packs, pending, plug, resistance, test, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
