1999 ford F350 6-speed transmission problems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-08-2011, 11:25 PM
bullman2009 bullman2009 is offline
bullman2009 is starting off with a positive reputation.
I have a 1999 Ford F350 Super Duty 6-Speed Transmission.I have a problem with 6th gear snap ring busting when I let off the gas. I just took the transmission out of the truck and replaced the snap ring for the first time. When I put the transmission back in the truck it did not last 2 miles and it done the same thing as it did before. When I put it in 6th gear it is like it is in nuetral. If anyone has any ideas what else might be wrong I would appreciate the feed back. Thanks!
Old 07-08-2011, 11:29 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
Welcome to the forum and sorry to hear about the problem. Sounds like the repair wasn't done too well? What is the mileage on the transmission? You might want to consider having it repaired by experts, or maybe replacing with new one is not going to be too expensive? Good luck.
6.0 transmission problems Dylanreynolds555 6.0L Power Stroke Diesel 5 08-02-2016 06:45 PM
Word to the wise, backing with 5th wheel attached olfordsnstone Fifth Wheel & Gooseneck RV Towing 9 03-20-2016 08:01 AM
Snap ring from Hell rlittlep 1999 to 2016 Super Duty 19 04-24-2014 10:46 PM
4X4 manual locking hub help Hogtrapper 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 02-16-2014 04:21 PM
1999 F250 SD 5th gear grind Nicks01ford Clutch, Transmission, Differential, Axle & Transfer Case 2 12-18-2009 09:11 AM
Tags
1999, 6th, diesel, duty, electrical, f350, ford, gear, problems, speed, super, trans, transmission, trouble, van, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
