Best performance parts for 351w? - Ford Truck Enthusiasts Forums
Old 07-08-2011, 08:20 PM
chevyassasin chevyassasin is offline
chevyassasin is starting off with a positive reputation.
I am looking to spend about $500 to $700 on performance parts for my 1996 f150 with a 5.8l and would just like some suggestions. what i'm looking for is h.p and torque gains, but a little more torque than h.p.. I am probably gonna buy summit racing shorty headers, over sized camshaft (I want it to lope), and get the heads port and polished. i just want the best bang for my buck and i don't know anything about mods for these trucks.
Old 07-08-2011, 08:27 PM
RednecksF150 RednecksF150 is offline
RednecksF150 is starting off with a positive reputation.
Don't waste your money on headers unless you wanna go longtube.
Old 07-08-2011, 08:29 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
If you want more torque go with long tubes on the headers , a lopey cam will give you more HP and TQ but it will be at a higher rpm....
Old 07-08-2011, 09:24 PM
ok, so any other recommendations? i should have a little money left over
Old 07-09-2011, 12:53 AM
Wynn96 Wynn96 is offline
Wynn96 is starting off with a positive reputation.
Gears before anything. Not technically more power or torque, but more seat of the pants power and torque. Oh and plan on $3-400/ differential (depending on 2 or 4wd)
Old 07-09-2011, 10:18 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Adding 1.7 roller rockers and longtube headers will produce solid TQ gains on the cheap, if you do opt for a cam consider something like the comp 35-320-8 or Crane 444211 but be aware these cams may require upgraded valve springs as well because the stock springs can only handle a little over 0.500" lift. Head porting is wasted dollars IMO, unless you are doing it all yourself it will cost $500-$1000 to get something worthwhile and for that money you can have brand new heads that are far better. Instead look for a pair if GT40s from a '96-97.5 Explorer/Mountaineer, thay have larger valves and flow about 20% better than the stock E7s.
Old 07-09-2011, 10:58 PM
alright thanks guys. i was looking at gearing, thinking about 4.10:1 cause that is what the lightnings have. Good idea? And what are some cheap differential options? I have been looking for some gt40 heads, but i only thought they were on the lightnings, so that should help alot with finding some. I'm thinking right now gt40 heads, long tube headers, and a cam. Plus maybe an intake manifold if i can find something cheap enough but worth putting on.
Old 07-10-2011, 02:44 PM
blkfordsedan's Avatar
blkfordsedan blkfordsedan is offline
blkfordsedan is starting off with a positive reputation.
I may be wrong, but I think your '96 should have a roller cam (?). The factory cam is not that terrible, and roller cams can be fairly pricey vs. the old flat tappet. I would start with a complete & quality tune-up w/ignition bump, a drop-in K&N filter, long tubes, a good dual exhaust and 1.7 rockers (if you have the money left over). 3.73 or 4.10 gears would also be a great "bang for the buck" upgrade. You can buy a set of FRPP gears for around $150 and plan on around another $200-$300 for install (unless you can set gears yourself). If the truck has some miles on it, I would also invest in new bearings. May be cheaper to find a complete used 3.73 rearend out of a salvage yard.
Old 07-10-2011, 05:10 PM
Duramaxfanatic1's Avatar
Duramaxfanatic1 Duramaxfanatic1 is offline
Duramaxfanatic1 is starting off with a positive reputation.
msd igniton box and increased plug gap, bump your timing, you can get a 6a box used for less then $100. the power gain is not substantial but you notice it doesnt have to try nearly as hard pulling weight or going up a hill
Old 07-10-2011, 05:13 PM
also you can look in to the ecm from a lightning i believe if you can match your tranny to what they had in the lightning then the lightning ecu has a more aggressive timing curve mustang ecu's may be the same if someone could confirm
Old 07-10-2011, 09:34 PM
any cheap air intake options? the k&n cold air intake is like $300 lol.
Old 07-11-2011, 12:06 AM
Quote:
anyone here will tell you to leave the factory air box alone, the only better mod would be to get a snorkel from a junk yard from an i6 or 460 equipt truck that draws the air directly from behind the grill, a drop in k&n replacement filter that fits directly to your stock box is best
Conanski's Avatar
Don't waste you $$ on those mislabeled cold air kits, the stock intake really isn't that bad with an (oilless)aftermarket drop-in filter and an intake snorkle from an I6 or 460 truck.
amazing performance and gas mileage rjkenney 1999 to 2016 Super Duty 8 04-24-2015 06:04 PM
460 efi performance upgrade BrianBoru Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 02-07-2012 08:48 PM
390 Performance Expectations? Azguy54 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 16 11-01-2011 08:27 AM
H.P. Gains from 408 Stroker Kit and other mods? chevyassasin Performance & General Engine Building 4 10-10-2011 05:23 PM
400 HP & Torque specs? 1980 Ford F-250 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 04-16-2011 07:53 AM
Tags
351, 351w, aftermarket, build, exhaust, exhust, f150, f350, for351w, ford, heads, mpg, parts, perforamce, performance, truck, upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
