dealer wants $2200.00 to replace particulate filter - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 07-08-2011, 07:11 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is online now
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
2008 f350 112,00 miles just had the truck in for a miss and the dealer says the particle filter is cracked and wants 2200.00 to replace it. Does this price sound about right for the job.
Old 07-08-2011, 07:39 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
Seems a bit high, but I'm having a tough time finding a price for the part. If your truck was built after 12/08, the part has an MSRP of around $1,500. What are they quoting you for labor?
At this point in time with no warranty you may well be best off installing a delete pipe and tuning the truck. Most common setups can be had for less than $1,500 and you'd have a truck that would get better fuel economy, more power, and one less expensive component to break. Check out these guys:
Spartan Diesel Technologies
On edit: Where in MN are you from? I work in Hudson, WI, which is only 20 miles from St. Paul.
Old 07-08-2011, 07:48 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Dealer cost on that part is $962.00 its also a super simply 40 min repair job. SO why the almost $1300.00 in markup?? The total repair should be around $1650.00 out the door.
Old 07-08-2011, 08:55 PM
Hey Crazy , we are located by forest lake.
Old 07-08-2011, 09:01 PM
Tom's Avatar
Wow...we're about 40 miles from each other. I bought my '11 F350 from Tousley Ford. Which dealer is quoting the obscene amount for the DPF replacement?
Old 07-08-2011, 09:20 PM
Hey Crazy I have a buddy that works in the parts dept at tousley. My dad has the 2008 down in branson Mo and its a dealer down there.
Old 07-08-2011, 09:34 PM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
Like Crazy said, since you are out of warranty you are better off spending $1200 or so and getting a DPF delete pipe and a tune. It is the best thing you will ever do to your truck.
Old 07-08-2011, 09:47 PM
Tom's Avatar
I just PMed someone in MO who might be able to offer some more advice. Hopefully he'll chime in soon.
Old 07-08-2011, 11:22 PM
pyro2nite's Avatar
pyro2nite pyro2nite is offline
pyro2nite is starting off with a positive reputation.
The DPF can be cleaned. Baked out or high pressure cleaning. Might want to check into that. Do the labor yourself. If it cracked then a must replace.
Old 07-08-2011, 11:29 PM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
I'm not real sure about pricing (I dont see the bottom lines, I just do the work) But parts, labor, and diagnostic time might be close to that figure. And no, I'm not someone that just replaces DPFs solely because of sooty pipes.
Old 07-09-2011, 01:28 AM
longview1's Avatar
longview1 longview1 is offline
longview1 is gaining momentum as a positive member of FTE.
Delete it, tune it and be done with it!
You'll be more than glad you did.
Old 07-09-2011, 11:07 AM
pyro2nite's Avatar
I agree with this. Just reducing the fuel contamination is worth it. The increase in fuel mileage is a bonus. To change mine over, tuner, delete pipe, custom tune 1125.00
Old 07-09-2011, 11:52 AM
longview1's Avatar
Quote:
It helped me sleep at night. Then the bonus of slightly better mpg-but any is a bonus, right? The longer intervals between oil changes is welcomed.
It took me all less than a few weeks to decide when I bought my 2008.
Old 07-09-2011, 02:23 PM
mattebury mattebury is offline
mattebury is gaining momentum as a positive member of FTE.
Isn't emissions equipment warranted for 10-years regardless of mileage?
Old 07-09-2011, 04:42 PM
Ronin 5729's Avatar
Ronin 5729 Ronin 5729 is offline
Ronin 5729 is gaining momentum as a positive member of FTE.
Out of warranty?
Is tuning even an issue then?
DPF-delete and tune, /thread...
And when you do come to the Dark Side, don't forget to get your cookie!
Jasper Luke Guihan 1978 - 1996 Big Bronco 4 06-02-2016 02:01 AM
ZF Transmission Replacement? 1Fastboy 1987 - 1996 F150 & Larger F-Series Trucks 2 07-16-2014 06:26 PM
Gauge cluster question. jim collins 1973 - 1979 F-100 & Larger F-Series Trucks 5 02-03-2014 08:02 AM
glow plug problems on 6.9 Marlinman10 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 33 03-12-2012 12:08 PM
4r100 trans smoked, need opinion JTATMAN 1999 - 2003 7.3L Power Stroke Diesel 30 05-30-2006 11:59 PM
Tags
2009, 60, 94, change, diesel, dpf, f150, f250, filter, ford, particulate, replacement, sct, warranty, x3
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
