6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
dealer wants $2200.00 to replace particulate filter
Old 07-08-2011, 06:11 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
2008 f350 112,00 miles just had the truck in for a miss and the dealer says the particle filter is cracked and wants 2200.00 to replace it. Does this price sound about right for the job.
Old 07-08-2011, 06:39 PM
Tom's Avatar
Tom
Tom is online now
Seems a bit high, but I'm having a tough time finding a price for the part. If your truck was built after 12/08, the part has an MSRP of around $1,500. What are they quoting you for labor?
At this point in time with no warranty you may well be best off installing a delete pipe and tuning the truck. Most common setups can be had for less than $1,500 and you'd have a truck that would get better fuel economy, more power, and one less expensive component to break. Check out these guys:
Spartan Diesel Technologies
On edit: Where in MN are you from? I work in Hudson, WI, which is only 20 miles from St. Paul.
Old 07-08-2011, 06:48 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Dealer cost on that part is $962.00 its also a super simply 40 min repair job. SO why the almost $1300.00 in markup?? The total repair should be around $1650.00 out the door.
Old 07-08-2011, 07:55 PM
Bigpipes 35
Hey Crazy , we are located by forest lake.
Old 07-08-2011, 08:01 PM
Tom's Avatar
Tom
Tom is online now
Wow...we're about 40 miles from each other. I bought my '11 F350 from Tousley Ford. Which dealer is quoting the obscene amount for the DPF replacement?
Old 07-08-2011, 08:20 PM
Bigpipes 35
Hey Crazy I have a buddy that works in the parts dept at tousley. My dad has the 2008 down in branson Mo and its a dealer down there.
Old 07-08-2011, 08:34 PM
Ian123's Avatar
Ian123
Ian123 is offline
Like Crazy said, since you are out of warranty you are better off spending $1200 or so and getting a DPF delete pipe and a tune. It is the best thing you will ever do to your truck.
Old 07-08-2011, 08:47 PM
Tom's Avatar
Tom
Tom is online now
I just PMed someone in MO who might be able to offer some more advice. Hopefully he'll chime in soon.
Old 07-08-2011, 10:22 PM
pyro2nite's Avatar
pyro2nite
pyro2nite is offline
The DPF can be cleaned. Baked out or high pressure cleaning. Might want to check into that. Do the labor yourself. If it cracked then a must replace.
Old 07-08-2011, 10:29 PM
vloney's Avatar
vloney
vloney is offline
I'm not real sure about pricing (I dont see the bottom lines, I just do the work) But parts, labor, and diagnostic time might be close to that figure. And no, I'm not someone that just replaces DPFs solely because of sooty pipes.
Old 07-09-2011, 12:28 AM
longview1's Avatar
longview1
longview1 is offline
Delete it, tune it and be done with it!
You'll be more than glad you did.
Old 07-09-2011, 10:07 AM
pyro2nite's Avatar
pyro2nite
I agree with this. Just reducing the fuel contamination is worth it. The increase in fuel mileage is a bonus. To change mine over, tuner, delete pipe, custom tune 1125.00
Old 07-09-2011, 10:52 AM
longview1's Avatar
longview1
It helped me sleep at night. Then the bonus of slightly better mpg-but any is a bonus, right? The longer intervals between oil changes is welcomed.
It took me all less than a few weeks to decide when I bought my 2008.
Old 07-09-2011, 01:23 PM
mattebury's Avatar
mattebury
mattebury is offline
Isn't emissions equipment warranted for 10-years regardless of mileage?
Old 07-09-2011, 03:42 PM
Ronin 5729's Avatar
Ronin 5729
Ronin 5729 is offline
Out of warranty?
Is tuning even an issue then?
DPF-delete and tune, /thread...
And when you do come to the Dark Side, don't forget to get your cookie!
Quick Reply: dealer wants $2200.00 to replace particulate filter
