Loosing transmission fluid - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-08-2011, 05:11 PM
omnicare omnicare is offline
omnicare is starting off with a positive reputation.
2010 f250 4wd diesel. 36000 miles. I am having to add 1/2-1 pint of transmisson fluid every 500 miles or so. I had it serviced at about 25,000 miles because i am pulling a fifth wheel RV. I have had it in the dealership and they can find nothing at all. I see no leaks either. No one seems to know where it its going? It has been suggested that the seals could be bad and it is going into the transfer case? Any ideas?
Old 07-08-2011, 05:24 PM
pduffy211 pduffy211 is offline
pduffy211 is starting off with a positive reputation.
That is a crap load of fluid, you should see it someplace. You can check the level in the transfer case to start but I'd start parking it in the same (hard covered) place all the time and watch for drips.
Old 07-08-2011, 05:33 PM
Thanks pduffy211. haven't seen the first drop on the ground. The underbelly is clean. I'm putting up on the rack tomorrow to check the transfer case level. Ever heard of that happening?
Old 07-10-2011, 12:13 PM
I'm not going to say it isn't possible but that much fluid transfer is going to come out of the transfer case seals or vent sooner or later. Might check this thread for other ideas.
F250 Transmission Leaks when backing - Ford Forums - Mustang Forum, Ford Trucks, Ford Focus and Ford Cars
Old 07-10-2011, 12:21 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
On some vehicles the oil can be sucked into the engine through a vacuum tube/hose and burnt but not famiar with this setup.
Old 07-10-2011, 03:42 PM
Sucked into the engine? Wouldn't there be smoke or something? I had it at the dealership in Roswell NM yesterday. The underbody was totally dry and the oil level in the transfer case was correct. NOBODY AT THE DEALERSHIPS HAS A CLUE. Should this be a warranty issue now should a file some kind of a claim?
Old 07-10-2011, 05:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
That system went out a couple decades ago. It can't happen on electronic transmissions.
Rebuilt Aviator trans due for 30k service Liquid_force Explorer, Sport Trac, Mountaineer & Aviator 3 05-19-2014 06:31 PM
Transmission Fluid In Radiator teddeshong 1987 - 1996 F150 & Larger F-Series Trucks 5 04-30-2011 03:11 AM
Auto. Transmission fluid change or flush? B 3000 Escape & Escape Hybrid 3 02-18-2010 07:41 PM
Escape Maintenance Schedule?? tonyford Escape & Escape Hybrid 23 01-08-2006 09:44 PM
92 Ford Aerostar (A4ld trans) 3.0 leaking trans fluid when driving 1+ hours cnajp Aerostar 23 09-21-2005 11:39 PM
Tags
250, diesel, f250, fluid, ford, losing, tranny, transmision
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
