Remove Gas from Tank? - Ford Truck Enthusiasts Forums
Old 07-08-2011, 07:15 AM
sjjones1 sjjones1 is offline
sjjones1 is starting off with a positive reputation.
2010 F-150 with 38 gallon tank. Original thought was great way of having some spare fuel available for use during an emergency. Can anyone please share how to easily remove gas from these new vehicles? Many thanks.
Old 07-08-2011, 11:15 AM
awq134's Avatar
awq134 awq134 is offline
awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.
step 1: get into vehicle
step 2: start vehicle
step 3: drive it like you stole it
step 4: stop just before you run out of gas so you can get back home
ha ha... I'm sorry, i just had to especially since there were no other posts.
In all honesty though, i really have no idea besides actually burning the gas the normal way.
Old 07-08-2011, 11:23 AM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
Most new vehicles have a closed returnless system and the tanks have check valves in the filler necks now in case of rollover, siphoning is a no go.
NotMyHusbandsF150's Avatar
NotMyHusbandsF150 NotMyHusbandsF150 is offline
NotMyHusbandsF150 is gaining momentum as a positive member of FTE.
Quote:
Do you mean for emergency purposes or for everyday use? If you need fuel on a daily basis, I'd recommend a portable tank in the bed but for emergency purposes, just buy a siphon. The make some cheap simple ones but you can use any type of hose. I've siphoned fuel from my dad's semi with a 3 foot piece of garden hose.
Old 07-08-2011, 12:00 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Quote:
But you've likely NOT siphoned from the new capless filler neck, have you? Go try it and let us know the results.
Old 07-08-2011, 12:14 PM
Use the funnel that comes with the truck that is MADE to hold the hole open... not exactly rocket science.
Old 07-08-2011, 12:45 PM
ebexp94 ebexp94 is offline
ebexp94 is starting off with a positive reputation.
This thread seems suspicious to me. Why would anyone want to siphon gas from their own truck? You can burn a tank in 2 weeks if you drive enough.
If you cant afford the gas you put in your truck and you want it back out, you shouldnt be driving a 2010.
Old 07-08-2011, 12:56 PM
I believe it is made to be next to impossible without the Ford provided funnel (to put fuel in with a gas can or even attempt a siphon procedure), anyways.
But, yah, you are right, if someone really wants to lug around some extra fuel - why not just buy a damn gas can and lug around some extra fuel?
Old 07-08-2011, 08:19 PM
being re-written.
Old 07-08-2011, 08:29 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I understand where you are coming from. Unfortunately, most all newer vehicles are designed so that fuel can not be stolen from the tank, thus no siphoning.
Old 07-08-2011, 08:46 PM
Archion's Avatar
The only thing I could see would be some sort of take off fitting in line. Something you could hook up to, turn the key on and fill a can. Something like HD trucks have for generators, reefer units and such.
Noise in rear gas tank Cooper-Ford 1987 - 1996 F150 & Larger F-Series Trucks 4 11-22-2014 08:40 PM
Gas tank removal 78 & 87 Super Cab 1957 - 1960 F100 & Larger F-Series Trucks 4 02-26-2014 06:15 PM
Gas tank removal twister2gt 1987 - 1996 F150 & Larger F-Series Trucks 38 12-18-2009 09:01 PM
siphoning gas from front tank to rear tank FordF350Baby 1987 - 1996 F150 & Larger F-Series Trucks 3 05-01-2008 09:52 PM
gas tank removal in 51 f1 Gwilkrrs 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-17-2002 07:58 AM
Tags
1977, 2008, 2009, 2010, 2011, f150, ford, fuel, gas, remove, removing, supercrew, syphoned, tank, tanks, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
