Low Boost Pressure and EGR Delete - Page 2 - Ford Truck Enthusiasts Forums
Old 07-14-2011, 10:37 AM
Blacksmith101 Blacksmith101 is offline
Blacksmith101 is starting off with a positive reputation.
While BlackChrome is fine with his lower boost, he is another data point. 06 with limited boost after the EGR delete was added. There has to be a reason.
Old 07-14-2011, 10:38 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
If the port is plugged where the EGR cooler inserts into the manifold, then you should be able to just install the valve and leave it plugged in.
Old 07-14-2011, 05:43 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
egr questions awnsered here http://www.ford-trucks.com/forums/97...egr-valve.html
remove the plate, reintall the valve and plug it in. looks more stock too.
also you will continue to get p0403 and a check enigne light. odds are it will come on every 2-3 days depending on driving.
Only 20lbs of boost kbf1961 6.0L Power Stroke Diesel 13 06-15-2015 03:50 AM
6.0 map psi drops when high boost psi ANigrelli132 6.0L Power Stroke Diesel 48 12-05-2014 10:49 PM
98 Exp EGR solenoid vacuum Thorntontribe 1997-2006 Expedition & Navigator 7 11-23-2014 03:30 AM
Annoying P0401 Code Towzilla 6.0L Power Stroke Diesel 23 04-17-2014 10:57 PM
Quick EGR Delete + Tuner Question GatorBait1996 6.0L Power Stroke Diesel 1 05-17-2012 06:21 PM
Tags
2003, 2004, 2005, 60, boost, cel, delete, egr, f250, f350, installing, low, p0401, power, pressure
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
