Is your M5OD shifting sloppy and cant find gears? UPDATE!!! - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 02-19-2014, 04:20 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
To REALLY throw you kids for a loop:
My Hurst Short Throw Shifter doesn't use the upper bushing.
Just uses the pins and lower bushing....
  #32
Old 02-19-2014, 06:21 AM
Krisverde Krisverde is offline
Krisverde is gaining momentum as a positive member of FTE.Krisverde is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by mefast View Post
Yup you got it right with the bolt and nut. A pretty slick system if you ask me.
As for the pivot pins, I can't really comment on how to remove them since mine were already loose and fairly worn. Pushing them back in with some thread locker has been doing the trick for now, but I ordered the bushing kit from the dealership the other day and it to help tighten things up a bit more. If you run into other issues, let me know.
I'm thinking perhaps the best bet to replace those pins is to pull that floor panel up so you have more room to maneuver around? Either way it feels much better than it did.
How do you like that shifter? I've been thinking about getting one. I believe core shifters sells the kit now.
This is random but where can one find the shift **** for the stick? Mine is all loose and falls off with ease. There isn't a set screw for it at all.
  #33
Old 02-19-2014, 07:21 AM
vzfiostech2's Avatar
vzfiostech2 vzfiostech2 is offline
vzfiostech2 is starting off with a positive reputation.
Curious, I am driving a 1994 f250 5 speed. Having to float a bit and regular shift. I can get first from a stop about 50 % of the time. I sometimes can touch the spinning plate if I push to hard into 3rd. I am starting in 2nd most of the time. I am thinking the slave cylinder at the firewall, but I love this kit. Is there a marking that can tell me the transmission model number? 4x2 300 6cyl. 176000 and going strong.
  #34
Old 02-19-2014, 10:09 AM
mefast's Avatar
mefast mefast is offline
mefast is starting off with a positive reputation.
Pulling the floor should give you better access. My truck is bare metal right now on the floor so it makes things pretty easy to see.
If you get the Core shifter, I wouldn't mind hearing a review on it. It looks good, but having someone that bought it comment on it would be better.
To fix my shift **** from popping off, I just put some super glue inside and stuck it back on. Hasn't been a problem since, but eventually I want a more permanent solution. For my birthday I got a tap set, so I may thread the top of the shaft and buy a shift **** from MGW, Hurst or someone like that.
  #35
Old 02-19-2014, 10:15 AM
mefast's Avatar
Quote:
Since you have a 5 speed, your only options are the M5OD like we have in this thread or a ZF5, assuming your transmission is a stock Ford one. If you can crawl underneith and snap a quick photo we can tell you what transmission. Your door sticker should explain what transmission you have if I remember correctly. Another option would be to google those two transmissions you should be able to tell after looking under your truck.
Just so everyone knows, apparently the dealership can only order the bushings in. The pins and cover are no longer sold by Ford. At least here in Canada they aren't.
  #36
Old 02-19-2014, 10:37 AM
On my door jam under the trans box I have an "M"
  #37
Old 02-19-2014, 11:13 AM
mefast's Avatar
Yessir. That's the same transmission we have.
  #38
Old 04-15-2016, 10:45 AM
Just did mine. No bushings whatsoever. Tighten it right up Thanks.
  #39
Old 08-25-2016, 11:14 PM
F150tx F150tx is offline
F150tx is starting off with a positive reputation.
Exactly what I need . Just ordered this. Thanks for the video and part supplier.
  #40
Old 08-31-2016, 07:02 PM
Installed the kit today. Took about 30 minutes. Bolt came out easy. Torx screws came out fine. I did not replace pins. Shifter is now firm, no rattle. Almost doesn't feel right being that I put up with wobble/rattle for so long. Thanks again for all the help on this.
1996 f150 regular cab 2wd, 214,000 miles.
  #41
Old 09-01-2016, 04:34 PM
Here is a pic of old and new.
M5OD-R2 Shifter sloppy zalinth Clutch, Transmission, Differential, Axle & Transfer Case 0 11-01-2016 05:58 PM
3 on the tree bushings... troymn 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-09-2015 06:08 AM
Sloppy gear shift 82fordowner 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-02-2013 09:44 AM
Help! m50d is stuck in gear!!! 86sixbanger Ranger & B-Series 3 09-17-2011 08:50 AM
Toby Keith Commercials A/Ox4 1999 to 2016 Super Duty 0 07-04-2011 05:49 PM
Tags
bushing, ford, gears, hard, issuesm5od, kit, loose, m5od, repair, shift, shifter, shifting, sloppy, sticky, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
