f1 performance
Probably not, Most flatheads run somewhat hot.
I don’t know much about flatties (or want to) and a professional specialist connoisseur will be along shortly to assist you.
It is common on old fords for the small wire underneath the distributor plate where the points sit to get worn and short out when the vacuum advance pulls on the plate, have a look at it.
This will bump your post to the top. Welcome to the site.
I would put a timing light on it as well, after checking the fuel filter. I’ve see too many times guy’s want to blame a running problem on the carb when its all timing. This is about the time the venturi vacuum comes in. you can check the distributor for movement of the plate with a vacuum pump. The late timing could explain the heating up as well. I would make sue your gauge information is correct. I can run 60mph all day at 180 take it up over 65 and it starts to climb.
Heating sounds about normal for my truck in the summer time. The gauges are woefully inadequate for accuracy.
I agree with the fuel supply for the spluttering - it's the most common cause. Tank clean or new? Lines new? Inline fuel filter in front of the pump?
Too much heat could cause the condenser to fail or even the coil.
