Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 07-07-2011, 01:28 PM
Nofearspear's Avatar
Nofearspear Nofearspear is offline
2006 Ford F-250
Nofearspear is starting off with a positive reputation.
Would like to burn WVO in my 06 250 SD
First id like to say what a great fourm!
Well to the point, i own a few restauants in north Texas and can get as much WVO as i need. With that being said,,,,whats the best plan for burnning some of this in my F-250 SD "06" 6.0 ?
I drive about 160 miles per day going from place to place all HWY.
NFS
  #2 (permalink)
Old 07-07-2011, 09:51 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Welcome to FTE and the Bio forum! I can't be of much help because I make biodiesel. Jason should find this thread, and he is "the bomb" with burning WVO. I'm sure he will be along shortly!
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 07-08-2011, 03:52 PM
flainn's Avatar
flainn flainn is offline
1994 Ford F-250
flainn is gaining momentum as a positive member of FTE.flainn is gaining momentum as a positive member of FTE.
I can't speak to how well a truck that new will handle WVO, but I can tell you that filtration of the oil is critical in any case. I recommend looking into a centrifuge -- Dieselcraft sells inexpensive ones, or you can spend several thousand on a really nice one with a PLC and variable speed motor. Most house filter solutions for WVO are insufficient to get the particle size low enough to not harm injectors and injection pump, especially on the newer high-pressure systems.
Also, heating the oil to the proper temperature before trying to burn it is essential to not getting carbon buildup. Many companies such as GreaseCar and Frybrid sell complete conversion kits that will give you everything you need to modify your truck to burn WVO. There's lots of good information out there. You will probably find that using WVO (as opposed to converting it to biodiesel) is a controversial topic; there are lots of people who will try to discourage you. But remember it's your truck and you can do what you want!
Good luck and welcome aboard.
__________________
'94 F-250 XLT 4x4 SRW, 7.3 NA (ATS 093 waiting to be put on), E4OD, 3.55, Alaskan telescopic camper, ATAS 120 and various ham radio gear (320k)
'91 Explorer XLT, 4.0, A4LD (192k), '96 Mercedes E300D (223k), '94 KX80, '96 PW80
Previously: '84 F-350 DRW, 6.9 NA, T-19 and '86 F-250 DRW, 6.9 IDI turbo (ATS 088), T-19, GVOD
  #4 (permalink)
Old 07-18-2011, 05:36 PM
timbrady timbrady is offline
Garage is empty, add now
timbrady is starting off with a positive reputation.
I have ~67,000 miles on WVO using this system in my 06 6.0:
WVO Diesel Conversion | SVO Grease Conversion | Ford Vegistroke Powerstroke | Biodiesel Conversion
You'll find lots of info here regarding the system:
BioFuels Technologies Forum - Powered by vBulletin
Ditto on the filtration. I use a Dieselcraft centrifuge, but there are other options as well.
With the mileage you are driving, you would get your investment back in no time.
  #5 (permalink)
Old 08-14-2011, 12:02 PM
HD Rider's Avatar
HD Rider HD Rider is offline
HD Rider has a good reputation on FTE.HD Rider has a good reputation on FTE.HD Rider has a good reputation on FTE.
After lots of searching, I found a pretty nice centrifuge for not a bad price.
They also sell parts to build your own if you want.
http://www.wvodesigns.com/wvo-centrifuges.html
__________________
Paul Zumpf
2000 F-250 4x4 CC LB
AIS, Zoodad, CCV, OCR, IH Bellowed Uppipes, GTP38R, 6.0L IC, Diesel Site Boots, 5" exh, AIH, Foil, and EBPV delet, Hutch/Harpoon, Coolant Filter, 203* T-stat, 08 Diff Cover, Bypass Filter, Tranny Cooler, Isspro EV2's, T-500 HPOP, WVO system, Tony Wildman Tunes
Tags
60, 60l, 64, burn, controls, conversion, diesel, dieselcraft, diesels, ford, powerstroke, sale, truck, trucks, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
