1985 Ford F-Series Rapid-Spec Price List and Ordering Guide PDF - Ford Truck Enthusiasts Forums
Old 07-06-2011, 10:06 PM
dohc_chump's Avatar
dohc_chump dohc_chump is offline
This space for rent...
dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.
Hey guys. I spent a bit of time today taking pictures and making a PDF file for those who'd be interested in reading the 1985 Dealer Rapid-Spec Price List and Ordering Guide for F-Series trucks. In it you'll find the available factory exterior color paint chips, option lists, engine info, option coding, what was available for the different trucks F150/F250/F250HD/Explorer package, pricing info, special order equipment, axle ratio codes, and more. There's some very good info in here and I turn to it for research frequently. If there's enough interest, I'll try getting some of my other literature up (none as useful as this file). Hopefully the site I'm hosting the file at works out. If anyone has any trouble downloading it, contact me and I can email you a copy when I get a chance. Enjoy!
1985 Ford Rapid-Spec Price List and Ordering Guide PDF
Old 07-06-2011, 11:43 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Chump - Thanks! To me that is invaluable. And, it is fascinating to read.
For instance, on Page 10 it says that the 302 EFI made 190 HP @ 3800 while the 351 HO makes only 210 @ an even higher 4000. Further, the 302 gave 285 lbs-ft of torque @ 2400 while the HO gave 302 @ 2800.
So, while some dis the 302 as being a horse power engine, and then only at high revs, it actually gave peak torque at less RPM than the 351. In fact, it gives only 7% less torque and 10% less horse power than the 16% larger engine.
Anyway, THANKS!
Old 07-07-2011, 12:22 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Downloaded. Thanks mate!
Old 07-07-2011, 02:38 PM
dohc_chump's Avatar
No prob guys! I figured some would put the info contained in the file to good use.
Old 07-07-2011, 03:40 PM
Sw1tchfoot Sw1tchfoot is offline
Sw1tchfoot is gaining momentum as a positive member of FTE.Sw1tchfoot is gaining momentum as a positive member of FTE.
Hmm, you could order an F150 with a 3.00 or a 3.08 gear.
So basically if you were knowledgable you could pick 3.00 to get a 9 inch or pick 3.08 to get the 8.8" rear axle.
Also, it says they used the New Process transmission in case the Warner was in shortfall.
Old 07-07-2011, 03:53 PM
Yeah, the same goes for 3.50/3.55. One was a 9", the other an 8.8".
As for the NP/Warner trans, wouldn't surprise me for one to used in place of the other. There isn't that much difference in how they function, so most buyers wouldn't know the difference.
I suspect the same was true in earlier years for auto trans. Might order expecting a C6, but get an FMX or C4 instead, depending on availability at the time..... They were all just refered to as "Cruise-o-matic" on the spec sheets and window stickers.
Old 07-08-2011, 10:17 AM
keyul's Avatar
keyul keyul is offline
keyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to all
Thanks for the guide! I already see a color I'd love to paint my truck, bright copper metallic! I am going to have to see if I can find a pic of a truck in that color.
Old 07-08-2011, 01:40 PM
im2tall33's Avatar
im2tall33 im2tall33 is offline
ID CHAPTER LDR
im2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputation
thanks for the guide!! maybe you could contact a mod and have this thread made a sticky!!! that way it wont get lost in the other threads
Old 07-08-2011, 03:44 PM
keyul's Avatar
Ah, looks like copper metallic was only offered on the econoline for that year!
Old 07-09-2011, 01:26 AM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
This is epic. I tried to hit you with the rep, but it says I like your posts too much.
Old 07-09-2011, 09:12 AM
Gary Lewis's Avatar
Quote:
Did it for you. Don't seem to have the same problem you have. Does that say I don't like anybody's posts?
Old 07-09-2011, 01:17 PM
I encountered the same issue. It seems almost everytime I try to rep someone, it keeps telling me to spread the love first.....
Old 07-09-2011, 10:07 PM
dohc_chump's Avatar
Thanks for the reps guys! Also, Chris contacted me about adding it to the stickies, so I think we're good to go there. Hope you guys are all keeping cool out there...
Old 02-17-2013, 09:19 PM
85blackbeauty's Avatar
85blackbeauty 85blackbeauty is offline
85blackbeauty is starting off with a positive reputation.
Great Read!
I just downloaded this manual and found it to be fascinating. I did not really know what the XL package consisted of before reading this. My XL seems to have parts of option packages available to the higher trim levels. Thanks for sharing this!
Old 02-18-2013, 03:04 AM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
Quote:
If you really want to be confused, scroll down and look at the over 8500# gvwr ratings, the HO only made 205 hp @ 4000, 295 tq @ 3000 in HD emissions trim, which makes little sense, as over 8500 trucks were subject to much more lenient requirements.
Also note that the 300 is listed as having peak torque at 1200, 1800 and 2000 rpm. All the while there are no induction, exhaust or camshaft changes...
2016 F150 Order guide?? HeavyAssault 2015+ F150 5 10-06-2016 09:08 PM
2017 Chassis Cab and Box Delete Owners Manual Rasalas 2017 Super Duty 0 07-25-2016 12:21 PM
Master Parts Catalog and Master Parts Index Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 04-01-2016 10:06 PM
add rear spring 2011 250 CC4x4 ..camper pkg owners out there? IWally 1999 to 2016 Super Duty 20 03-29-2012 08:55 AM
2011 Super Duty Order Guide available on FTE! powerstroke72 1999 to 2016 Super Duty 3 12-19-2009 05:17 AM
Tags
1985, axle, bullnose, dealer, duty, explorer, f150, f250, f350, factory, heavy, lariat, options, pdf, price, sheets, truck, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
