1985 Ford F-Series Rapid-Spec Price List and Ordering Guide PDF - Page 2 - Ford Truck Enthusiasts Forums
Old 02-18-2013, 08:30 AM
9wire's Avatar
9wire 9wire is offline
9wire is gaining momentum as a positive member of FTE.
Perfect, since I have an 85. Thank you, sir.
Old 02-18-2013, 09:51 AM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
82F100, the HD trucks were presumably down rated for enduring higher work loads and may have had different tuning for that, not for emissions reasons. That's they only reason that makes sense to me.
Thanks, DOHC...
Of other note, the base price of an 85 F250 SuperCab 4x4 would be approximately $28k in today's dollars.
Old 02-18-2013, 10:57 AM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
Can't rep you, gotta spread it around, but good work!!
Old 03-24-2013, 12:49 AM
dohc_chump's Avatar
dohc_chump dohc_chump is offline
This space for rent...
dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.
No problem guys. Haven't been on in a month... sorry to bring this back up for air.
Old 03-24-2013, 09:48 PM
Salomon Trujillo Salomon Trujillo is offline
Salomon Trujillo is starting off with a positive reputation.
Quote:
Originally Posted by dohc_chump View Post
Hey guys. I spent a bit of time today taking pictures and making a PDF file for those who'd be interested in reading the 1985 Dealer Rapid-Spec Price List and Ordering Guide for F-Series trucks. In it you'll find the available factory exterior color paint chips, option lists, engine info, option coding, what was available for the different trucks F150/F250/F250HD/Explorer package, pricing info, special order equipment, axle ratio codes, and more. There's some very good info in here and I turn to it for research frequently. If there's enough interest, I'll try getting some of my other literature up (none as useful as this file). Hopefully the site I'm hosting the file at works out. If anyone has any trouble downloading it, contact me and I can email you a copy when I get a chance. Enjoy!
1985 Ford Rapid-Spec Price List and Ordering Guide PDF
do you know where I can get the one for a 1983?
Old 03-25-2013, 03:27 AM
oneowner83 oneowner83 is offline
oneowner83 is gaining momentum as a positive member of FTE.oneowner83 is gaining momentum as a positive member of FTE.
I'm struck by the HIGHWAY fuel mileage for the 4.9 six with the 4 spd overdrive....24 mpg. My '83 with the same setup I believe was published at 22. I would get 21-22 with a 3.08 axle and carrying more weight due to being a SuperCab..... turning only 1600 rpm at 60 mph. Pretty cool!
Old 03-26-2013, 07:52 PM
wherron wherron is offline
wherron is starting off with a positive reputation.
Smile
WOW! Chump.. Just downloaded your file and it is packed with useful intel. Thanks man. This save a great deal of research and key pounding. Good looking out.
Old 03-01-2014, 02:22 PM
djjsc djjsc is offline
djjsc is starting off with a positive reputation.
'85 truck 302 vs 351W
Quote:
Originally Posted by Gary Lewis View Post
Chump - Thanks! To me that is invaluable. And, it is fascinating to read.
For instance, on Page 10 it says that the 302 EFI made 190 HP @ 3800 while the 351 HO makes only 210 @ an even higher 4000. Further, the 302 gave 285 lbs-ft of torque @ 2400 while the HO gave 302 @ 2800.
So, while some dis the 302 as being a horse power engine, and then only at high revs, it actually gave peak torque at less RPM than the 351. In fact, it gives only 7% less torque and 10% less horse power than the 16% larger engine.
Anyway, THANKS!
That must be a late '85 document. Spring '85 Ford introduced the 302 multiport EFI engine w/ 190HP in the F series. I think the earlier carbed version was approx 150-160. All '85 351Ws were carbed (4V Holley); referred to as the 351HO. I have an air cleaner off one; decaled "351HO". It was considerably more powerful than the carbed 302.
Old 05-07-2014, 04:50 PM
BeefcurtinS's Avatar
BeefcurtinS BeefcurtinS is offline
BeefcurtinS is starting off with a positive reputation.
Ive been looking for this!! I wonder if i can find if these trucks had a fender flare option from the factory?? guy i bought the truck from said they were custom installed but others have said its from ford that way. buchwacker plastic is way better then what ive got.
anyway Thanks a bunch!!!!!!!!
2016 F150 Order guide?? HeavyAssault 2015+ F150 5 10-06-2016 08:08 PM
2017 Chassis Cab and Box Delete Owners Manual Rasalas 2017 Super Duty 0 07-25-2016 11:21 AM
Master Parts Catalog and Master Parts Index Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 04-01-2016 09:06 PM
Ford 6.0L Student Training Guide bismic 6.0L Power Stroke Diesel 11 11-13-2012 03:31 PM
add rear spring 2011 250 CC4x4 ..camper pkg owners out there? IWally 1999 to 2016 Super Duty 20 03-29-2012 07:55 AM
Tags
1985, axle, bullnose, dealer, duty, explorer, f150, f250, f350, factory, heavy, lariat, options, pdf, price, sheets, truck, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
