Lots of '73-'79 Parts - Parting out 2 1979 F350's
Category: Accessories
Price: $20
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude, FCX
Item Condition: PA
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
Everything on this list is current and available:
- Complete restored 6" lift kit with front & rear springs, sandblasted, painted, new bushings, rear blocks, pinion degree shims, adjustable drag link, drop pitman arm, dual steering stabilizers with brand new shocks, kicker shock setup for rear leaf springs to prevent axle wrap, new hardware etc - MUST SEE (see other ads)
- NP435 4-speed trans out of running & driving f-350 custom complete with frame/bellhousing mounted linkage, shift fork, throwout bearing, shifter, shifter boot & Hurst shifter handle (no np205 adapter)
- Good 11" clutch & flywheel used with 400 motor but originally from 351m motor
- Front Dana 60 part-out including gears, carrier, cover, steering arm, hubs, yoke etc (NO HOUSINGS OR COMPLETE AXLES, see other ads)
- Set of (4) original 16.5" steel wheels
- 31"x10.50x16.5 used tires and wheels
- NEW ignition parts (almost the entire ignition, coil, relay, distributor etc)
- Holley Carb from 400 motor (model 4150/4160, 390cfm street/strip carb)
- Edelbrock Performer 400 intake
- good fuel tank complete with float assembly
- filler neck
- hood latch assembly
- transmission cooler and radiator
- auto transmission linkage from column
- NP205 transfer case shifter, shifter **** and chrome trim around shifter boot (NO cases or 4wd shifter boots)
- Speedometer cable
- Manual steering column complete with levers
- Steering wheel
- Front CV driveshafts
- Rear driveshafts
- 1-ton tie rod
- 160A High Output alternator!
- transfer case heat shield from snowfighter
- transfer case sandwich frame mount
- front grill mount brackets (3) and all hardware
- 3-piece transmission/transfer case crossmember complete with hardware
- rear f-250 snowfighter leaf springs
- Solid (no rot) V-Force dual exhaust complete with hangers/flanges from single cab copper colored truck
- all exterior chrome trim from cab forward
- front dana 60 u-bolt brackets
- rear dana 60 u-bolt brackets
- Rear Leaf spring blocks
- Rear Leaf spring blocks with bumpstops
- throttle kickdown rod with c-clips for auto trans
- used starters in good condition
- Good windshield with rubber and chrome trim in good condition
- Rear glass with sliding windows complete (with good rubber)
- EXCELLENT condition front radiator core support/front bumper & fender support
- Black sun visors
- 100mph guage cluster from F-350 Custom
- 80mph guages (3 different ones from F-350's & F-250 lariat snowfighter)
- Ignitions with keys
- White hood with NO rot in great shape
- Chrome Front Bumper - good
- Hood hinges, mounting tracks
- White tailgate from F-350 Custom complete with aluminum badging
- Tailgate hinges
- Left tail light
- Upper and lower door hinges
- Windshield wiper arms
- Chrome step trim inside door on floor
- Tail light chrome trim
- Blue seatbelts
- White glove box door
- Ford dog-ear reversible mirrors needing new glass from F-350
- Red, white or black ash trays, original cigarette lighters
- Chrome door pulls
- Plastic door lock pulls
- Window cranks with black or clear plastic *****
- F-250 Custom badges
- F-250 Ranger badges
- F-350 Custom badges
- XLT badges
I am currently parting out 2 '79 F-350's and 1 '78 F-250 (2 with 400M/C6/NP205/D60 front/D60 rear) (1 with 400M/NP435/NP205/D60 front/D60 rear) so let me know what you guys need and make an offer. Trucks are located in Schnecksville, PA 18078..about 10-15 mins northwest of Allentown.
Additional photos HERE:
Some pulled parts:
http://imageshack.us/g/339/p1040071p.jpg/
Plow & flatbed photos on Copper F-350:
http://imageshack.us/g/215/p1040164u.jpg/
Blue F-250 and front of Copper F-350:
http://imageshack.us/g/715/p1040320n.jpg/
Blue F-250 exterior:
http://imageshack.us/g/135/p1040352c.jpg/
Copper F-350 interior, ignition, exhaust, crossmembers, leafs, pulled parts etc:
http://imageshack.us/g/818/p1040711.jpg/
SEE PAGE 9 FOR MORE PICTURES
Alot of these parts will fit f150s f250s and f350s from 1973 to 1979..
Copper '79 F-350 XLT: had 95k a flatbed and snowplow (both sold), holley carb, edelbrock performer 400 intake, all new ignition parts. The front axle is sold. Gauge cluster is spotless. 31" TIRES AND WHEELS with 90% tread STILL AVAILABLE CHEAPPP. Check out the pictures above in albums for parts..
Blue '78 F-250 Lariat: WITH 55,000 ORIGINAL MILES and had a good running 400 (SOLD), C6 (SOLD). It has fender flares, good interior (seatbelts still available, most all else sold), great mirrors (SOLD), fuel tank, good 4x4, good tailgate (SOLD)...Pass door (SOLD).
White '79 F-350 Custom: with 158,000 original miles, a 400 motor (sold), NP435 4-speed (available as well as clutch/flywheel, hood & tailgate with trim both still available. Good windshield & rear sliding glass.
Plastic fender flares: 2 good front, 1 good rear, 1 rear broken but repairable with fiberglass kit.
The flatbed is 100% around the perimeter and has what I called speckled hen rust on the top. There is no place where it worn through though. It's solid, just needs to be cleaned up. Mounts are good. Make an offer.
Check the first line of the post for location, Schnecksville, PA 18078, about 10-15 northwest of Allentown.
First I just thought I d say I noticed a funny, the tool box in the back of the first truck is exactly what I just put in mine.
Business: I am interested in the rear leafs as long as the are off a one ton (as you have listed), how much for them and shipping?freight 54235 sturgeon bay WI.
I am actually seeling this truck now, but would like to get it in the best shape for whomever does make the best offer. So what about throwing the 78-79 grill shell into that price as well. Thanks for the heads up your a good man.
Boomer
Boomer
Not sure if it would work at all, and only if you think it would be worth the effort. I could have a copy of the key for my tool box made and send it your way? Helpin a neighbor
Boomer
Boomer
The second truck has cruise control..
Like the steering wheel etc? I won't be able to pull the steering wheel on the second truck quite yet, until I get it into the garage. Let me know what ya need and make an offer. You got first dibs on it..
Sorry, I don't have these..the bolts were torched out during disassebly and the rubber mounts were already shot..
