Lots of '73-'79 Parts - Parting out 2 1979 F350's
#346
Category: Accessories
Price: $20
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude, FCX
Item Condition: PA
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
#348
Everyone, here is the current list:
I ONLY have what is on the list below!
Everything on this list is current and available:
- NP435 frame/bellhousing mounted linkage, shift fork, throwout bearing (NO TRANS JUST THE PARTS) (NOW SITTING IN THE SCRAP BIN, SAVE IT OR IT'S GOING)
- Good 11" clutch used with 400 motor but originally from 351m
- Front Dana 60 gears, carrier, cover (NO HOUSINGS OR COMPLETE AXLES, see other ads)
- 31"x10.50x16.5 used tires and wheels (3 left, 1 is new unmounted)
- NEW ignition parts (almost the entire ignition, coil, relay, distributor etc)
- transmission cooler and radiator
- auto transmission linkage from column
- NP205 transfer case shifter, shifter **** and chrome trim around shifter boot (NO cases or 4wd shifter boots)
- Speedometer cable
- Manual steering column complete with levers
- Steering shaft
- Steering wheel
- Front CV driveshafts
- Rear driveshafts
- 1-ton tie rod [passenger (long) side and adjusting collar good]
- 160A High Output alternator!
- transfer case heat shield from snowfighter
- transfer case sandwich frame mount
- front grill mount brackets (3) and all hardware
- 3-piece transmission/transfer case crossmember complete with hardware
- rear f-250 snowfighter leaf springs
- V-Force dual exhaust complete with hangers/flanges from single cab copper colored truck GOING TO BE JUNKED SHORTLY, I NEED THE ROOM
- front dana 60 u-bolt brackets (only the top brackets available now)
- rear dana 60 u-bolt brackets
- Rear Leaf spring blocks
- Rear Leaf spring blocks with bumpstops
- throttle kickdown rod with c-clips for auto trans
- Rear glass with sliding windows complete (with good rubber)
- EXCELLENT condition front radiator core support/front bumper/fender support
- Rare 100MPH Black-background gauge cluster in great shape
- Silver guage clusters (2 different ones from F-350's in great shape)
- Ignitions with keys
- White hood with NO rot in good shape
- Hood hinges, mounting tracks
- Tailgate hinges
- Left tail light
- Upper and lower door hinges
- Blue seatbelts
- White glove box door
- Red, white, blue or black ash trays, original cigarette lighters
- Chrome door pulls
- Plastic door lock pulls
- Window cranks with black or clear plastic *****
- F-250 Custom badges
- F-250 Ranger badges
- F-350 Custom badges
- XLT badges
#350
Here is a picture of ONE of the guage clusters (this is obviously not the 100mph black set). Not sure what's in the reflection but they're in great shape. $35 plus the ride for an 80mph cluster.
Looking for $100 on the rear sliding window complete. Go to fedex's website with estimated dimensions to get an idea on shipping. Weight shouldn't be a factor. My zip is 18078. If still interested let me know and I'll get you a price.
#355
those are long gone...only what's on the list ^^^
#356
Here are a few pictures of the high amp alternator from '79 F-350 with 400m. Newer alternator came off truck with dual optima batteries and a plow. Should fit any ford with spade shaped alternator. Standard alternators are 40 amp. This is made by Motorcraft, 75 Amp.. $40
