What Color IDM
ICM Color
Wow made me feel real old! I do understand the difference. It's my nature to wonder why manufacturers feel they can make one item fit all and get away with it. You've been super helpful. I'll keep you posted on how this thing works out. One symptom I noticed is when restarting a hot engine there seems to be a kick-back just as it fires off like when the timing is too far advanced. Ever have that happen or hear of it?
All engines should crank at Base Timing (10 Deg BTDC) in most Ford in our era of the Forum.
If you have the wrong ICM installed you may not be cranking at Base Timing and that would explain the hot kick back.
IE: Gray with no start wire accepting SPOUT info, Black with the Gray computer sending SPOUT info before start while cranking.
ICM Color
Even my Haynes manual has it wrong. They show 92 and up for the wiring diagram which shows pin 4 on the PCM going through a ignition suppression resistor with the tan-yellow going to pin 2 on the ICM and a tan yellow to the coil. I ordered the DY1077 for a 1995 5.0 and it is black. Should be right.
MONAVIERONJON
02-24-2021 03:31 AM
fns
10-20-2011 09:10 PM
