Oil thinner than 0W-20 on the way
As long as the engine is specd for it and the tolerances need something thinner, all will be good. Just like how well 5w-20 does in engines now. Even in a 300+ 4.6 liter ohc, it brings back excellent uoa's. Im on a phone browser so I didn't open the link yet, but I wonder what engines will be using this thinner oil?
At operating temp, Not all engines oil pump can provide the flow/volume needed with lower viscosity lubes & the manufacturers aren't likely to spend the money retest older engines for wear in the pump & or engine, to determine if the pump can keep up.
As an example, Fords 4.0L comes to mind, as it was never back speced to use 5W-20.
Using a lower viscosity crankcase lube than specified, isn't likely to make a measureable mpg difference to the average driver anyway.
I never changed my 3.8L over to the back speced 5W-20, as it's doing just fine on 5W-30!!!!
I wouldn't either. The 05 Mustang GT calls for it, though. My mom isn't a hot rodder, plus all the 4.6 ford UOA'S I've seen made me want use Pennzoil Platinum 5W-20 in her car. I do hot rod it, though, lol, and the factory gauge always sits high. But those modular engines do great on thinner oils no matter what.
porthole
6.7L Power Stroke Diesel
05-03-2013 07:44 AM
preppypyro
17
09-22-2008 12:38 AM
