2007 5.4L Ticking Noise - Ford Truck Enthusiasts Forums
Old 07-06-2011, 08:49 AM
AFordMan AFordMan is offline
AFordMan is starting off with a positive reputation.
I have a question about my 2007 F150 4x4 with the 5.4L. It has a ticking noise sound coming from somewhere around the motor, but it's not there till the motor has warmed up. It almost sounds like a exhaust leak, but I'm not sure. Any one have any ideas to what it might be , or can you tell me what to look for? Thanks
Old 07-06-2011, 09:02 AM
MCDavis's Avatar
MCDavis MCDavis is online now
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Possibly an exhaust leak, could also be cam phaser related. Possible that the injectors have become noisy as well. As you can see, a few things can lead to an audible "tick".
How's the truck running? Any drop in fuel efficiency?
Old 07-06-2011, 09:09 AM
The truck run great, it has around 55,000 miles on it. When it is idling you can't hear it, but if you reab it up you can here it, but only after the motor has been driven about 10 miles and has warmed up. We just took it on a 1000 mile trip and got around 16 to 19mpg on it, but we were towing a trailer with a car on it.
Old 07-06-2011, 08:45 PM
JoshNHRA JoshNHRA is offline
JoshNHRA is starting off with a positive reputation.
I had this exact same issue, and the right side exhaust manifold was cracked.
Old 07-06-2011, 09:28 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Could be a loose plug too. Try to isolate it to one side then pull the coils on that side. if any of the boots have carbon on it then that plug is loose.
Old 07-07-2011, 07:22 AM
Thanks for that info, I'll check that after work tonight.
Old 07-07-2011, 10:48 AM
driller tom's Avatar
driller tom driller tom is offline
driller tom is starting off with a positive reputation.
My truck is doing the exact samething, its definately on the drivers side but you can only hear it when it's in first gear. Does this sound like an exhaust leak?
Old 07-10-2011, 05:40 PM
Quote:
Right side cracked? How did you determined it was cracked? I checked to see if I had a loose plug and found nothing after finding out it was on the right side also. I got under the truck and the sound is coming from the manifold.
Old 07-12-2011, 08:42 PM
It was changed under warrenty, so i dont konw how they found it. I assume they listened for the sound up close, or ran thier hand around the manifold to feel the exhaust coming out. The service advisor said this was a common issue.
Old 07-13-2011, 08:07 AM
'2007 5.4L Ticking Noise
Thanks, I don't want to take it to the dealer ship but maybe I will. This noise is getting worse and It's really bothering my wife to drive it.
Old 07-14-2011, 09:52 AM
JRStow JRStow is offline
JRStow is starting off with a positive reputation.
I have an 05 f-150 4x4 and I had an obnoxious exhaust leak on the pass. side... WITH ALOT OF PATIENCE, I removed the manifold(both sides of course), and replaced the 3 piece gaskets. 55000miles later and still no leak. if you are going to do this yourself bc the dealerships are crooks, be patient. AND CAREFUL. I was both, and still ended up breaking several studs off in the head. In which was not easy to get to as the manifolds are so close to the frame rails. Ford even stamps their FoMoCo badge on the gaskets... hold your truck at 1200 rpm under load by driving it... see if the noise gets louder...could most likely be cam phasers. If so ANYONE EXPERIENCING CAM PHASER ISSUES... I INSIST YOU BUY THESE!!!http://www.compcams.com/catalog/COMP...g_2010_365.pdf
GOOD LUCK SIR.
Old 07-14-2011, 02:02 PM
Quote:
GOOD LUCK SIR.
Thanks this will help.
Weird rattling noise and ticking noise while idle nicholas116 2004 - 2008 F150 1 12-28-2016 08:15 PM
2007 5.4L Ticking Noise AFordMan 2004 - 2008 F150 17 02-19-2016 05:55 PM
Ticking noise Superdutystiller 1999 to 2016 Super Duty 3 05-07-2015 02:51 PM
2007 5.4 3v ticking ingerson 2004 - 2008 F150 3 07-27-2014 07:47 PM
04 FX4 engine ticking and stalling Bull1717 2004 - 2008 F150 3 04-25-2011 12:26 AM
Tags
2007, 54, 54l, davidson, edge, engine, f150, ford, harley, left, noise, side, started, ticking, ticks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
