Steering wheel size question. - Ford Truck Enthusiasts Forums
Old 07-06-2011, 04:33 AM
BIGskinny BIGskinny is offline
BIGskinny is starting off with a positive reputation.
What's the size of a stock 90 f150 steering wheel?
Im looking to put a smaller one as I'ma bigger fella in a reg cab just to give me some more room with the Steering wheel. I'm looking at a 10in wheel from summit think thats to small?
Old 07-06-2011, 05:36 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Im thinking the stock size is like 15" , i would not go smaller than 13" ....Lew
Old 07-06-2011, 11:30 AM
Ten four. Is there down falls to a smaller wheel?
Old 07-06-2011, 04:52 PM
jokerforever's Avatar
jokerforever jokerforever is offline
jokerforever is gaining momentum as a positive member of FTE.jokerforever is gaining momentum as a positive member of FTE.
here's a cool 10" steering wheel I found on the photobucket
<a href="http://photobucket.com/images/chain%20steering%20wheel" target="_blank"><img src="http://i144.photobucket.com/albums/r200/ohioturboranger/IMG_0177.jpg" border="0" alt="10&amp;quot; chain steering wheel ! Pictures, Images and Photos"/></a>
All you need after that is some dingle berries hanging from the windshield and whitewalls running on 13" gold wire Daytons
A steering wheel acts as a lever. The shorter the lever the less leverage you'll have. That means the more steering effort that you'll have to put into the wheel to turn it. That's why when you look at older cars from the 60s on back, especially the ones without power steering, they have massive steering wheels. The suggested 13" is really on the small side. I don't think I would want to drive a truck with anything smaller than 15".
Old 07-06-2011, 06:19 PM
lew52's Avatar
I didn't suggest a 13" wheel , i said i would not go any smaller , i use a 14" wheel in my truck and its fine , stock is 15 , my 70 396 BB nova only had a 14" wheel in it with no power steering , no problem steering it ...
Old 07-06-2011, 06:53 PM
I'm 5-10 305 not a small fella the 15 is ok in there now but I'd like a few inches smaller give me a lil more room for turning as I tend to use one hand alot. I'm not to worried bout it being a little harder to steer. Just lookin for a little mire room.
Old 07-06-2011, 07:14 PM
lew52's Avatar
I cant tell the difference between the 15-14" , with power steering you don't need alot of leverage , so its up to you ...if some can't drive a truck with a little smaller wheel they need to man up......Lew
Old 07-06-2011, 08:23 PM
I think I can handle a few inch smaller wheel. I drove my dads old chevy with no power steerin for almost a year it'll be fine. I agree lew a think a 12-13 is the smallest wheel to consider. Any thing else is stupid small.
Old 07-06-2011, 09:04 PM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I wouldn't change the steering wheel. I don't think the stock wheel is all that big to begin with. Compared to many classic cars its small. Anyway the quality of most aftermarket wheels is sub par.
Old 07-06-2011, 09:21 PM
Quote:
Your right it's not big at all but, for a bigger guy in a reg cab the inch or two more clearance from a smaller wheel would make driving abit more comfortable. IMO anyways.
Old 07-06-2011, 09:46 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
If you dont already have tilt wheel, you could swap the column out.
Old 07-06-2011, 11:21 PM
That has crossed my mind also. Headin to look for one soon. Thanks for the replys.
Old 07-06-2011, 11:36 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
I'm with bashby here, tilt would be more convenient, especially if there is another driver, as in wife or GF.
Old 07-06-2011, 11:54 PM
Oh yea I agree with both of y'all no doubt. Going to go look for one very soon. The extra room will be nice as I'ma bigger guy n could use a little more steering wheel room.
Old 07-07-2011, 12:28 AM
I would definitely upgrade to the tilt wheel column.
steering wheel for a 55 ford f100 gangstakr 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-09-2015 09:59 AM
Painting a steering wheel rexblue 1961 - 1966 F-100 & Larger F-Series Trucks 5 06-14-2015 12:34 AM
'51 steering shaft dimensions (including splines) @ steering wheel end DW SD 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 03-06-2015 02:49 PM
steering wheel change. papazig4726 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-23-2015 06:47 AM
Steering Wheel Mounting Bolts TPyle 1961 - 1966 F-100 & Larger F-Series Trucks 3 07-06-2014 04:26 PM
Tags
06, 150, 1996, 2000, 2003, diameter, dimension, f150, f250, ford, measurement, size, skin, steering, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
