towing
Old 02-24-2015, 07:16 PM
dale49's Avatar
dale49
dale49 is offline
towing
I have 1990 F250 reg cab, long bed,460 engine. I also just bought a 33 foot,2 slide 5th wheel. When I pulled it home, I noticed the back was sitting down a little bit. Is that normal or is it something that can be done to correct it. I am not sure of the weight, probably 10k.I am not sure either of the towing capacity of the truck . I would appreciate any information. Thanks
Old 02-24-2015, 07:30 PM
ponykilr's Avatar
ponykilr
ponykilr is offline
Load distributing hitch perhaps. Add a leaf or two to the rear pack. Air bags.
Old 02-24-2015, 07:40 PM
MI02SVT's Avatar
MI02SVT
MI02SVT is offline
Yup air bags or helper springs
Old 02-24-2015, 08:39 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
That is ALOT of camper. probably too much for your truck.
What gears and trans?
Old 02-24-2015, 10:36 PM
Conanski's Avatar
Conanski
Conanski is offline
Originally Posted by dale49
I just bought a 33 foot,2 slide 5th wheel. When I pulled it home, I noticed the back was sitting down a little bit. Is that normal
Ahh.. yeah.
Check your owners manual, if the truck has a manual trans you're way over capacity unless it's got 4.10 gears, with a auto it's right at the limit with 3.55 gears.
Old 02-25-2015, 05:49 PM
Old Trusty's Avatar
Old Trusty
Old Trusty is offline
Bag it, and a trans. temp gauge, electric fan, a good trailer break controler, and it you don't already have it a large trans cooler
Old 02-25-2015, 10:04 PM
shryock10's Avatar
shryock10
shryock10 is offline
So following this thread a 1990 f250 with a 460 and 4.10 gears what's my towing capacity? No owners manual
Old 02-25-2015, 10:33 PM
f100beatertruck's Avatar
f100beatertruck
f100beatertruck is offline
460/Auto:
3.55 GCVW 15,000
4.10 GCVW 18,500
460/Manual
3.55 GCVW 12,000
4.10 GCVW 16,000
Figure a regular cab, 4x4 weighs 6-7k lbs that leaves about 11,500 on the high end or 5k on the low side...
Old 02-26-2015, 12:03 AM
892504x4's Avatar
892504x4
892504x4 is offline
Sorry wrong info, have to start over.
Clyde Ford
1999 to 2016 Super Duty
17
12-05-2016 06:48 PM
todouble
Fifth Wheel & Gooseneck RV Towing
11-28-2013 05:01 PM
Jayybird
6.7L Power Stroke Diesel
16
01-10-2013 02:48 PM
65F1005.8
11-22-2010 08:51 PM
mwwebb8
04-13-2004 07:29 PM
Quick Reply: towing
