Steering wheel size question.
on
They didnt offer air bags back then, did they? It should be pretty straightforward, remove trim under dash, 4 bolts hold the column in, I believe. Then you've got a pichbolt at the end of the shaft and wiring to unplug.
smaller wheel
Would also like to know where I can find a used one at a good price? On a tight budget. Want around a 12". My 1990 has a tilt wheel, btw. Also will the adapter that I am told will be necessary bring the wheel closer to the driver?
touchfordtruck
11-20-2016 12:10 PM
Uni Moe
06-17-2016 05:22 PM
Justin73supercamper
06-02-2016 10:10 PM
