EGR Cooler Horizontal - Leak????
I could use some help. I noticed a fluid leak at the coolant supply hose on the horizontal EGR cooler. Upon visual inspection, the edge of the hose is wet where it connects to the cooler. I dropped by a local Ford dealer and the mechanic took one look and said, "you have a failed EGR cooler, expensive!"
Looks like a loose hose clamp to me with fluid around this connection. Am I missing something here?
I have no white smoke. I noticed a wet spot on the driveway which got me looking for the leak. My resevior was nearly empty but I haven't checked the level in a while.
Senix,
I'm 325 miles from home and my trusted mechanic. I'll get a hold of a flat blade this afternoon. I'm more concerned with the local mechanics quick visual observation and whether I can make it home.
I know this hose leak has left residue all over the back pressure sensor and the under body but what am I missing that made the mechanic believe this is a failed cooler? I have no white smoke and the reservoir is holding fluid.
Thanks again, Rob
Thanks again, Rob
I'm back! My truck is at Ford and BulletProof EGR Coolers are on order shipping next day air.
Ford gave my rig a clean bill of health last year after pressure testing my EGR coolers. A loose hose clamp was the culprit that time around.
This time I noticed a loss of power on Wednesday cutting out at 2500 RPMs. The next morning I drove into work and while parking, the engine light came on and I couldn't go more than 5mph. The engine idled perfectly, just wouldn't go. I had AAA tow her into the dealer yesterday.
The thrown code was pointing my mechanic to a bad EGR valve which they replaced but also found engine coolant beneath. So here I am again, 126K miles and my first pair of EGR coolers.
I considered an Elite Diesel EGR delete kit for a moment. I hope I didn't make a mistake.
The Navistar Maxxforce 7 (6.4) does not use 2 EGR coolers any more, there down to 1 cooler. Just wondering if their new setup is compatible with the Ford 6.4 version.
I doubt it, as I believe the Maxxforce 7 has always used one EGR cooler from the beginning in 2007. The Super Duty pickups have to pass a completely different set of emissions tests than medium duty trucks that the Maxxforce engine would be in, and I believe this is why the different turbo and EGR system.
