Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-05-2011, 08:17 PM
Jakegday Jakegday is offline
Garage is empty, add now
Jakegday is starting off with a positive reputation.
78 ranchero loose steering
hello all. i just acquired a 78 ranchero with a 302 and 3 speed C4 automatic. the steering wheel seems very loose, like there is alot of play in it. I was wondering what may be causing this.. any input would be greatly appreciated. thanks!
  #2 (permalink)
Old 07-05-2011, 11:03 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Worn out parts. Start at the rag joint in the steering column, just above the box. From there, every moving part is suspect. Have someone move the wheel as you inspect each joint in the linkage. The box itself may be worn out as well.
  #3 (permalink)
Old 07-15-2011, 05:06 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Ed, there is no "rag joint" on this vehicle.
What there is...is a lower steering shaft and coupler assy. The steering box end has a round plastic bushing, the other end has a flexible joint which wears out.
There is a separate clamp (D3OZ-3A525-A) that has splines on it which slide onto the gearbox input shaft.
The coupler has two studs, two nuts retain this clamp to the coupler. A thru bolt is used to tighten the clamp to the input shaft.
If the thru bolt has worked loose, this will cause play, but the most likely suspect is the flexible joint of the coupler itself.
D4OZ-3B676-A (replaced D2OZ-3B676-C, D3OZ-3B676-A) .. Lower Steering Shaft & Coupler Assy / Obsolete
Applications: 1972/73: Torino/Ranchero/Montego / 1974/76: Torino/Ranchero/Montego/Cougar / 1977/79: LTD II (not an LTD!) / Ranchero/Thunderbird/Cougar.
AFAIK, this was a FoMoCo Dealer item only / Last MSRP: $225.88 / Dealer net cost: $135.53.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
No FoMoCo Dealer, no other obsolete parts vendor has any.
jakegday: VERIFY this coupler is causing the problem before buying it, as it might be the P/S gearbox itself, or...
It could be a worn draglink, and/or tie rods, tie rod ends.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 08-09-2011, 06:01 PM
hello. thank you for the reply, and sorry for the delay in responding.. you are correct; it was indeed that coupling assembly. rockauto.com had a similar part, but i decided to just get this part from autozone and "rebuild it"
Help/2 5/8 in. dia. Chrysler, Ford and GM 1965 and newer steering coupling (31002) | Steering Coupling Disc | AutoZone.com
the piece i bought was a hair to small, but since its rubber i was able to make it stretch, and the problem is now gone
Tags
1978, 78, 79, column, ford, joint, linkage, loose, play, rag, ranchero, steering, thunderbird, wheel, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
