Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 07-05-2011, 07:03 PM
TALLBOY86B.C.C TALLBOY86B.C.C is offline
Garage is empty, add now
TALLBOY86B.C.C is starting off with a positive reputation.
Exclamation Please Help (New ford truck owner)
Ok so i have just recently purchased a 1963 F 100 unibody. The truck originally was a 3 on the tree but the previous owner switched it to on the floor. Does anyone know what linkage i need because they just kind of threw something together.. It is the stock 3-speed Man.Trans. Any Other information about the truck will be greatly appreciated!
  #2 (permalink)
Old 07-05-2011, 07:22 PM
64blue's Avatar
64blue 64blue is offline
1961 Ford F-100
64blue is starting off with a positive reputation.
I had the same issue. I took out the floor shifter and reinstalled the column shift. I was able to pull the shift linkage off of a donor that was a 64 f100 (non-unibody). If I remember correctly, the shift linkage from 61-64 will work. 65 and 66 will not. I will measure the two rods tomorrow and post a reply. P.S. this site has a user named "Number Dummy" that can give you the actual parts numbers for these.
__________________
Gota' Love The "Twins"
* 1978 Ranger 4x4, 351M
* 1966 Custom Cab 352 Shortie
* 1964 F100 223 Shortie
* 1961 Uni 292 Shortie
  #3 (permalink)
Old 07-06-2011, 02:48 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
C3TZ-7326-E .. 2nd/3rd Shift Rod / Obsolete
Applications: 1961/64 F100/250 2WD 3 speed M/T / 1961/64 F100 3 speed M/T with Overdrive.
C1TT-7328-F .. 1st/Reverse Shift Rod / Obsolete
Applications: 1961/63 F100/250 3 speed M/T / 1961/64 F100 3 speed M/T with Overdrive.
At the bottom of the steering column under the hood are the two manual control selector levers that these shift rods attach to.
See if these parts are still present. If not, you will need the two levers, misc attaching parts, the two bushings and insulators.
The usual reasons why peeps convert to a floor shifter:
1) The shift lever's pot metal shift collar that attaches to the shift tube breaks apart internally, causing the shift lever to flop around. And/or...
2) The two bushings/insulators that fit into the selector arms age crack, then fall apart, causing the shift lever to bind up.
Peeps are clueless where to get these parts (obsolete, but all can be found NOS), so they install a floor shifter instead.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 07-06-2011, 06:31 PM
Thanks a lot for your help 64blue!
  #5 (permalink)
Old 07-06-2011, 06:42 PM
Another thing..I have no breaks so I am rebuilding the master cylinder with a rebuild kit, also replacing all four wheel cylinders and brake lines..Any other suggestions?
  #6 (permalink)
Old 07-06-2011, 08:30 PM
kjvforme's Avatar
kjvforme kjvforme is offline
1962 Ford F-100
kjvforme has a very good reputation on FTE.kjvforme has a very good reputation on FTE.kjvforme has a very good reputation on FTE.kjvforme has a very good reputation on FTE.
It your choice but you might want to think about upgrading to discs in front and going to a boosted master cylinder. It all depends on what you want to do with the truck, restore to original, or modify to your liking.
__________________
Rob
1962 Ford F100 flat bed 4x4, 223, 4spd.
1962 Ford F100 Unibody with Olds 330 & Jetaway
1944 Ford GPW (Jeep) with 1947-48 Willys L-134
To join the Oregon Chapter, click HERE
  #7 (permalink)
Old 07-07-2011, 03:54 PM
Im more into the 50's rat rod look lol I want to eventually slam it on airbags keep the motor and trans original.
Tags
2011, 64, 7328, f100, f150, fan, ford, forum, heater, linkage, number, owner, part, shift, truck, trucks, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
