2.3l no spark at two plugs - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-05-2011, 06:54 PM
samiam1017 samiam1017 is offline
samiam1017 is starting off with a positive reputation.
i have a 94 ranger with the 2.3l engine there is no spark at the ignition modual (the front one both on the drivers side) that controls the plugs on the drivers side of the engine. i swapped with the modual for the exhaust side but the problem stays at the same two plus and doesnt move with the modual what can be the source of this problem? ECU? thanks in advance
Old 07-05-2011, 11:15 PM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
There isn't any spark at the ignition module. Are you talking about the coil packs? If you swapped the coils and there is still no spark then you need to test the wiring for that coil to the PCM. If the wiring tests good, then replace the PCM.
Old 07-06-2011, 07:20 AM
dorman68 dorman68 is offline
dorman68 is starting off with a positive reputation.
I would try a fresh set of spark plug wires. I had a similar issue about a year ago and new wires cured by problem.
Old 07-06-2011, 07:26 AM
tomw tomw is online now
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
I thought the drivers side spark plugs were only active in certain circumstances. In other words, they don't fire all the time. I may be wrong, but have you tried putting a timing light on one of the plug wires and watching if it fires at all? It may be normal.
Do you have any codes or CEL/SES light lit on the dash?
tom
Old 07-06-2011, 10:27 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Sounds like normal operation. The drivers side plugs are not supposed to fire at startup. Replacing the PCM will not change the result, the EDIS system is a standalone ignition controller, the PCM does not control spark directly. The computer only controls timing and dwell.
Old 07-06-2011, 11:20 AM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Which two plug cyl numbers don't have spark????
I like tomw's idea to check for spark with a timing light.
If no joy, check the coil packs primary windings for continuity & it's electrical connector for B+ to each coil primary winding at KOEO.
If that checks out, suspect the coilpacks ground wiring for the troubled coil, all the way back to the computer, as it supplys the coilpacks primary ground switching, to operate the coil packs to fire the spark plugs, so if the ground wiring checks out ok, suspect the computers ground switching driver has a problem.
If all that checks out ok, check the end to end resistance of the two troubled plug wires.
They should measure about 1000 ohms/inch of length, 30k ohms max, no matter the length.
More thoughts for consideration, let us know what you find.
Old 03-24-2014, 05:35 PM
trvitesse trvitesse is offline
trvitesse is starting off with a positive reputation.
Right side of front coil not firing
Have a 1994 For ranger with the 2.3Liter engine. Front coil on right side not firing. Checked coil, Okay. Found problem to be ICM. Purchased a new from Napa. Model TP503. Corrected firing problem but now the truck will only run for 1 - 2 minutes before stalling. Returned the ICM back to Napa
and exchanged for more expensive unit. Model TP503SB. Same problem occurred. Returned unit back to Napa. After some conversations with the manager. Store refunded my money. Purchased used Motorcraft unit from wrecking yard. Truck runs great!!
Some of the aftermarket ICM's are not compatible.
fuel pump driver modual jdiam00 1999 to 2016 Super Duty 2 06-09-2013 04:30 PM
!999 ford E350 7.3L deisel goodybrain2001 1968-2013 Full Size Vans 5 11-30-2012 10:58 AM
89 f150 bogs down? |WYG|SS 1987 - 1996 F150 & Larger F-Series Trucks 16 05-24-2011 12:18 PM
84 4.9 I-6 no spark after 5 min running mxhowes1 Ford Inline Six, 200, 250, 4.9L / 300 15 06-25-2010 05:59 PM
Stumped ono_55 Bronco II 10 09-06-2008 11:10 PM
Tags
1994, 23, 23l, 93, 94, 96, controls, cylinders, ford, ignition, install, module, motor, ranger, spark, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
