Truck Steps
Truck Steps
Hey guys, I need to put a set of steps on my truck so the old lady can get up in it.........I really like the classic look of the Carr Hoop II steps, but they dont list any for dents........however they do list them for E series vans starting at 1975.5..............any one have any idea if these will bolt right up somehow, or what would need done to fit them?
Hoop II Steps
Hoop II Steps
Back to the thread.. them steps are fine for trail riding and stuff but I find they would hang down too low and get hung up, bent, or get ripped off (physically).
I prefer tube steps / frame-mounted sliders. Haven't found any specific for a Dent but I do have a tubing bender.
I was just curious if I could make the ones for the van work, I assume they bolt to the frame?
Just today I was working on a set of steps for my '75 F-250. It has a 3" cab lift, and my wife currently uses an inverted 5 gallon bucket to clamber into the cab, with me pushing from behind !! She's a shorty, but she's soft and sweet. . .
The wife - not the truck. . .
I'm trying to make my steps frame mounted, but not sure of the feasability of the idea. It requires a 24" arm welded to a 7" vertical mount. I'm gonna go ahead with my plan, but might have to abandon it for something with less leverage. Anybody else make their own steps?
Paul
Paul
If you look close at this pic, hopefully you can see the Carr steps that are on my truck. This was taken several years ago, but I've never had any issue at all with these steps and will be re-installing them when the resto is finished. I think they are great, never loosened up and the black powdercoat is still in excellent shape. I also liked them because in my opinion they don't take away from the lines of the truck. They bolt to the back of the lower rocker and are rock solid, no need for long brackets to the frame.
Paul
Paul
Imagine two 10" or so long 1/4 wall angle bolted vertically to the frame. Then he had two pieces going out horizontally from bottom of those verticle pieces to under the step itself which was a course open mesh screen like near 1/4" wire (it didn't bend or flex when you stepped on it) in a frame of angle. Then there were two braces angled up from just underneath the cab out of view that went to the tops of those verticle pieces bolted to the frame sides.
Now build two, one for each side of the truck for balanced looks and to remind the driver that there's a like step over on the pass side.
Then lastly, he used two pieces just wider than the frame itself to bolt to tabs welded on (he welded tabs on for bolts so would not have to drill the angle itself and weaken it in some way) between the verticle pieces, so that each side supported the other side's verticle pieces against flexing inward below the frame, yet allowed each side to be installed or removed one at a time, or the centers in case of need for service / repaior.
He primed and painted his. When he was meassuring, I remember he parked the truck level and dropped a plumb bob off the side to establish the maximum width, he was careful to not have the steps wider than the truck's body. His steps were about 3 feet long, just guessing. They extended just about to rear edge of cab, I remember you could stand on them and be close enough to reach over into bed at front. The front end was near the front of the door, maybe not quite. Certainly not to fender.
Wish I had pics to post, that was in the late '70s early '80s, probably weigherd near 100 lbs total. He also cut and welded his own front grill guard and hitch. The truck's long gone to some farmer in Ga. after my BIL took it south.
Especially if you were pulling carpet and maybe added some thicker steel in the floor to spead load or etc?
