Back passenger window won't roll up... - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-05-2011, 02:42 PM
AndeyHall's Avatar
AndeyHall AndeyHall is offline
AndeyHall is starting off with a positive reputation.
My passenger side back window won't roll up. It won't roll up from either switch. If one switch is bad, will it cause both to not work, or am I looking at a new pw motor?
Old 07-05-2011, 03:01 PM
fz1dave's Avatar
fz1dave fz1dave is offline
Super Duty
fz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud of
I would guess it's the motor or the wiring to it. Time to pull the panel and have a look.
Old 07-05-2011, 04:15 PM
AndeyHall's Avatar
Well one second it rolls down, 2 minutes later it won't roll up. Get in it to drive to a doctors appointment and it won't work the entire way there (I would just randomly try). Then when I park, out of habit I just hit all 4 window buttons to roll them up and it goes right up. What's up with that?
Old 07-06-2011, 08:16 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
my bet is the drivers side master switch...
i had teh exact same scenario.. rear window stuck down (neither switch would bring it back up)
new master switch fixed it. good part is you get a new power door lock/window lockout with the new swtich
Old 07-06-2011, 11:19 PM
Livn-lg Livn-lg is offline
Livn-lg is starting off with a positive reputation.
I had this exact same issue. I bought a switch for the passenger rear door, no dice. I got a switch for the driver door and again, no dice. After 2 days of trouble shooting it found the wire cracked in half inside the driver door loom. Soldered back together and it works great. I would recommend getting the meter out and testing the switches prior to buying new ones as I learned the hard way. Just my .02c
Old 07-07-2011, 09:41 AM
AndeyHall's Avatar
Yeah I figured it was a broken wire or intermittent master switch once the window went back up. I'll have a look at it once I get back home from vacation. But right now I got a turbo not working so the window's kinda the least of my worries lol
Help rolling up window temporarily Autoarcheologist Expedition & Navigator 2 08-21-2015 12:06 PM
passenger side window won't roll up. remj93 1999 to 2016 Super Duty 0 03-16-2015 08:37 PM
Mirror and window motors queen of spades 1999 to 2016 Super Duty 4 03-11-2015 12:45 PM
Window will not roll up BLariat 2004 - 2008 F150 2 04-16-2009 04:14 PM
Main Window Switch? pablocruz69 Expedition & Navigator 1 03-28-2009 12:44 PM
Tags
1997, 2004, explorer, f150, f350, ford, motor, passenger, power, rear, roll, side, window, windows, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
