Fuel tank selector valve - how to test. - Ford Truck Enthusiasts Forums
Old 07-05-2011, 12:41 PM
Myfreeford's Avatar
Myfreeford Myfreeford is offline
Myfreeford is starting off with a positive reputation.
75 F250, 460, camper special, 2WD.
Problem:
Tank selector switch is set to the front tank which is almost full of fuel. The rear tank is empty. When I switch to the front tak, there is a click noise that comes from the tank selector valve. The truck does not start - it continues to turn over as if it were out of gas. The selector valve would not normally make any noise when changing tanks, which makes me think it is going/gone bad.
Temporary solution:
I connected the fuel line directly from the front tank to the fuel pump and bypassed the selector valve. Truck runs great and I can still use the selector switch to see how much fuel is in each tank.
Question: How would I go about testing the valve to be sure it is actually the valve that is bad and not something in the switch? The fuel selector valve has one wire - I have not followed it to find out where it leads to. I picked up a new universal selector valve from Napa - but I would rather confirm that the other one is toast before I install this one.
Thanks.
Old 07-05-2011, 12:48 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
D5TZ-9189-B (replaced D5TZ-9189-A & D8TZ-9189-A) .. Fuel Tank Selector Valve & Solenoid Assy-mounts on frame rail / Obsolete
Marked: D5TB-9F271-AA or D8TB-9F271-AA or D9TB-9F271-AA // Last MSRP: $118.35 / Dealer net cost: $71.01 // SIX available NOS from three sources:
PARTS INTERNATIONAL in Farmers Branch TX has TWO = 888-727-0418.
KINSEL L/M in Beaumont TX has TWO = 800-816-2894.
HIGH BUCK!! BOB ALLEN FORD in Overland Park KS has TWO = 800-676-0675. Call this source only as a last resort, cuz this 'snake' wants mega-bucks for obsolete parts!
D5TZ-9A050-A .. Fuel Tank & Fuel Gauge Selector Switch, mounts into heater control panel / Available from Ford.
MSRP: $35.67 // FTE sponsor PARTSGUYED.COM price: $19.26.
Selector valve applications: 1975/79 F100/350 & Econoline with dual fuel tanks / Switch applications: 1975/79 F100/350 only.
Note: The switch is used to change the tanks and the dash fuel gauge.
1973/74 F100/350's used a manually controlled brass selector valve that mounts on the floor adjacent to the drivers side of the seat.
The heater control panel mounted switch (D3TZ-9A050-A) only changes the fuel gauge from one tank to the other.
Last edited by NumberDummy; 07-05-2011 at 01:06 PM. Reason: Post edited to add more info and for clarification.
Old 07-05-2011, 12:55 PM
Myfreeford's Avatar
Quote:
Originally Posted by NumberDummy View Post
1975/79 F100/350's with dual fuel tanks use: D5TZ-9189-B .. Fuel Tank Selector Valve & Solenoid Assy which mounts on the frame rail.
The switch: D5TZ-9A050-A mounts into the heater control panel, switches the tanks and the dash fuel gauge.
1973/74 F100/350's used a manually controlled selector valve that mounts on the floor adjacent to the drivers side of the seat. The dash mounted switch only changes the fuel gauge from one tank to the other.
Thank you for the part numbers. Since I disconnected the fuel line from the fuel selector valve, I was able to locate it. I am not sure how I would use this info to check and see if my existing valve is bad or not.
Old 07-05-2011, 01:20 PM
Note: I edited my post adding much more info...
Fuel Gauge Problem Boodrow379 1994.5 - 1997 7.3L Power Stroke Diesel 2 04-20-2015 05:29 AM
Tank selector valve/sending unit Heesman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 06-05-2014 05:51 AM
Fuel Gauge Open Circuit Diagnostics Help Franken-Truck Electrical Systems/Wiring 2 12-18-2011 06:20 PM
Tank Selector Valve 88 250 1987 - 1996 F150 & Larger F-Series Trucks 1 10-06-2010 07:17 PM
Duel tank selector switch bad2thebone 1987 - 1996 F150 & Larger F-Series Trucks 6 07-05-2009 11:43 PM
Tags
1974, 78, 9b, bronco, changing, crossover, d8tb, e350, f250, ford, fuel, selector, switch, tank, test, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
