ECM Location on a 99 F350 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-05-2011, 12:49 AM
BuddhaKat's Avatar
BuddhaKat BuddhaKat is offline
BuddhaKat is starting off with a positive reputation.
I've purchased my first F350 PSD and I'm adding some stuff to it. One of the things I'm adding needs to tap into a couple of wires going to the ECM, but I don't have any idea where the ECM is located on my truck. It's an early 99 model F350 with a 7.3 L diesel. I've already added a chip to the PCM, but there seems to be some confusion about what a PCM and an ECM is on another forum. To be frank, I have no idea, but I suspect they're different. Could they be combined? I don't see how.
Old 07-05-2011, 12:57 AM
ToMang07's Avatar
ToMang07 ToMang07 is offline
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Quote:
They're the same thing. You have 3 major Modules: PCM(or ECM), IDM, and GEM. What are you tapping into? Be extremely careful as to not fry ANY of the above. Very expensive "whoops".
Old 07-05-2011, 01:25 AM
BuddhaKat's Avatar
It's for a BD TorqLoc and exhaust brake. Unfortunately, with all the little production changes that go on, it's hard for an aftermarket supplier to put out a set of instructions that fit each truck exactly. Unfortunately for me, it gets a little confusing.
Old 07-05-2011, 01:38 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Look at page 9 here.
http://www.dieselperformance.com/pro...5_Torqloc4.pdf
It tells you that what you need on your truck is on the PCM. Some other makes (in this case Dodge) calls it an ECM.
Old 07-05-2011, 05:01 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
PCM is (I believe) Powertrain Control Module - which includes Engine (ECM) and Transmission brains.
In the gassers, the PCM is between your left foot and the parking brake pedal mechanism.
Old 07-05-2011, 05:08 PM
A/Ox4's Avatar
9 ECHO 1
Same place on the diesels.
Old 07-05-2011, 05:24 PM
BuddhaKat's Avatar
Excellent, thank you. I was thrown off because in the instructions for the TorqLoc it says to splice intp a couple of wires in the ECM. I called Cam at BD and he confirmed that there's no ECM on my truck.
I don't want to even think about the time I spent researching this over the weekend. Hours looking for an answer when I could have been flippin burgers on the barbie.
1995 VEX1 ECM Good for MAF Swap GuitarJesus Ford Truck Parts for Sale 0 04-27-2016 03:34 PM
Swapping used ecm Bkemp 2009 - 2014 F150 4 10-23-2015 07:43 AM
ecm wilbilly216 1987 - 1996 F150 & Larger F-Series Trucks 17 09-03-2011 01:50 PM
'91 E-350 ECM PROBLEMS WHALEY 1987 - 1996 F150 & Larger F-Series Trucks 3 08-13-2010 09:30 AM
ECM Part Number LeeroyDiesel 1999 - 2003 7.3L Power Stroke Diesel 6 09-03-2009 06:07 PM
Tags
1994, 1999, 350, 99, control, ecm, engine, f250, f350, ford, located, location, module, navigator, wheres
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
