93 F150 Running WAY TOO rich - Ford Truck Enthusiasts Forums
Old 07-04-2011, 11:32 PM
BigJared BigJared is offline
BigJared is starting off with a positive reputation.
Working on a 93 F150 2wd. Had bad motor. We replaced it with a 5.0 from a 94 Mustang Gt. engine has an E303 cam, full length headers, 2.5 inch pipe off of headers into custom y pipe into single 3 inch in and out flowmaster, no cats, new O2 sensor. starts easy. idles fair. sounds EXCELENT. it fouls plugs in less than 5 gallons of fuel during testing and idleing in the driveway. you can see it and you can smell it in the exhaust. it is bad.
anyone let me know. I understand this is a bit much cam for speed density, but I would think it would be too lean, not too rich.
Peace.
Old 07-05-2011, 07:35 AM
please help anyone....
peace
Old 07-05-2011, 08:02 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Are there any codes and is the fuel pressure within spec? That cam is not at all compatable with the EFI system in that truck so it will have to go if you want decent drivability from this.
Old 07-05-2011, 10:23 PM
Thanks.
No codes.
Haven't checked the fuel pressure yet.
I understand there will be a slight driveability issue, but I have seen the combo work in S/D Mustangs. I should be able to check the fuel presure tomorrow.
Do you know if the 93's were "batch fire" or "sequential port" on the fuel injectors? we had this combo in an 86 F150 with stock "batch fire" ecm and it ran fine with the stock cam versus the E-cam. I had rewired the injector harness to "batch fire" properly with the HO-302 firing order versus the standard truck firing order. I have not rewired the 93 injector harness.
Thanks again.
Old 07-07-2011, 10:03 PM
mr.fordneck's Avatar
mr.fordneck mr.fordneck is offline
mr.fordneck is starting off with a positive reputation.
my 90' was running too ruch. A new wiring harness fixed it
Old 07-08-2011, 06:53 AM
CS45's Avatar
CS45 CS45 is offline
CS45 is starting off with a positive reputation.
When my F250 5.8 was running rich it was caused by exhaust leaks before the O2 sensor. Fixed that with a complete new exhaust and no leaks, not running rich, no CEL.
CS45
Old 07-08-2011, 07:05 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Have you checked the fuel pressure regulator for signs of leaking? Pull the vacuum line off of it, visually inspect and smell it for signs of fuel. Very common problem to have a leaky FPR diaphragm.
The '93 trucks were all batch fire BTW.
Old 07-08-2011, 07:27 PM
Thanks everyone. I hope to be able to try and check all of that tomorrow.
Old 07-19-2011, 11:07 PM
Well I finally got time to work on it. I rewired the injector harness on the engine.
because of the differences of the old firing order versus the new H.O. firing order. The injectors fire in batches that follow the firing order. Because of this there was puddling of fuel or something causing the single fuel injector to see a lean condition and telling the computer to send more fuel.
Now all I have left is the "surging" at idle.
Thanks to you all.
Old 02-15-2013, 07:26 PM
makingaZJ makingaZJ is offline
makingaZJ is starting off with a positive reputation.
Thanks to you all.
Hey man i have a 89 with a mustang 5.0 ho around the same specs, and you can watch the gas needle fall while it sits in the driveway!! x2 smell it ect..
what exactly did you rewire? how? im still running everything stock for the truck as of now, besides the firing order of course..
thanks
-Nate
Old 02-15-2013, 09:24 PM
Conanski's Avatar
Exactly what wiring changes did you make? The batch system fires 4 injectors at a time so I don't see how it would make any difference.
1991 5.0 runs extremely rich ShaneNP123 1987 - 1996 F150 & Larger F-Series Trucks 15 03-21-2016 02:11 PM
New 351w running rich and bad idle '90-f150-302-5spd 1987 - 1996 F150 & Larger F-Series Trucks 17 03-25-2015 02:21 PM
Poor cold driveability, new motor, HO cam hivoltj 1987 - 1996 F150 & Larger F-Series Trucks 63 03-29-2012 06:50 PM
strong fuel smell in exhaust fumes? cjben 1987 - 1996 F150 & Larger F-Series Trucks 10 11-30-2008 05:59 PM
F100 hesitation stumble when accelerating from stop eddieandgayle 1967 - 1972 F-100 & Larger F-Series Trucks 11 05-12-2007 12:30 PM
Tags
1987, 1990, 351, 49, 58, 93, bronco, f150, f250, ford, fuel, injected, rich, running, v8, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
