Fuel Pressure ?
Fuel Pressure ?
Hello my 2001 V10 has been having a couple of hesitation problems it happened a few days ago, then today. It just acts like it was out of gas for about 2-3 seconds. I have a scan Gauge and it is not throwing any codes, and My superchips programmer is not showing any codes, even though I am not running any program right now.
So I just hooked up a fuel pressure gauge. With the ignition on but not started I have 22PSI. With the truck running at idle I have 32PSI. But at 3000RPM and even 4000RPM I still only get 32PSI.
I need to go on a 250 mile trip tomorrow and wondering if I should cancel. I am thinking maybe the fuel pressure regulator, but I need to figure it out before I have to leave on my trip. I won't be towing anything.
So please I need help ASAP. Thanks.
I am not an expert on this subject but can share this is different behavior then I see on my 2000 V10. I see 32 psi at idle then a jump to 40 psi under heavy acceleration then it settles out 38 psi while cruising at 3000 rpm. I hope that this helps…maybe someone with more experience with this subject will jump in shortly.
Ok I went on my trip of 330 miles. the truck ran fine most of the time, but I had some more hesatation and it would only happen crusing at around 1600-1800 RPM. So after looking at other posts I am getting a sense of maybe a bad coil. But not sure yet. I still don't know why my fuel pressure stays at 32 PSI, and not more. Also I am still not getting any codes. My fuel filter only has 2000 miles on it, but I am going to replace it this weekend.
Does anyone have any more thought on this? I talked to my local Ford garage and they said if there is no code then they don't know what it is.
Thanks,
P.S. My truck just turned 75,000 miles today.
Thanks,
86stepsideF150
06-28-2010 09:23 PM
toolboxjunky
04-09-2009 05:01 AM
