Speedometer Cable Routing - Ford Truck Enthusiasts Forums
Old 07-04-2011, 06:24 PM
ssj7kids's Avatar
ssj7kids ssj7kids is offline
ssj7kids is gaining momentum as a positive member of FTE.ssj7kids is gaining momentum as a positive member of FTE.
53 F1oo
Obviously goes from the speedometer to the trans... there is a hole in the firewall that my before pictures seem to illustrate that it goes through.
However from there......?????
Pictures? description?????
thanks
Old 07-04-2011, 11:24 PM
Okiedokie's Avatar
Okiedokie Okiedokie is offline
Okiedokie is starting off with a positive reputation.
Goes under tranny cover doesn't it? Tomorrow I will look at manual. Been too long since I ran mine.
Old 07-05-2011, 07:33 AM
ssj7kids's Avatar
I looked in the manual and couldn't find anything.. (doesn't mean it's not there...)
The hand brake goes under the tranny cover, but it seems like the speedo went through the firewall, and with the steering, brake and clutch pedals and shift linkage all in the same area, I'm not sure how the cable runs....
Any and all help appreciated.
Old 07-05-2011, 09:43 AM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Quote:
I think (read as: a I donít know wild a$$ guess) itís the other way around.
Old 07-05-2011, 10:30 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
It's different between 48-50 and 51-52, not sure about 53-56 and beyond. On 51-52 it goes thru a hole in the firewall right near center of the firewall, loops down and goes along the trans to the rear. It shares the hole in the firewall with the choke cable and throttle cable. Just keep it away from electrical stuff in the engine compartment (my cable has a bare steel sheath, some are plastic coated).
Previous thread:
http://www.ford-trucks.com/forums/90...l-opening.html
Old 07-05-2011, 11:15 AM
Okiedokie's Avatar
On my 53 [not restored] I ran the emergency brake cable and the speedo cable both thru the recess in the upper drivers side of trans cover. I was sure that the factory manual showed this, but a quick look thru did not find it. I may be wrong about that being "factory".
Old 07-05-2011, 12:23 PM
mechmagcn's Avatar
mechmagcn mechmagcn is online now
Diesel Junky
mechmagcn has a very good reputation on FTE.mechmagcn has a very good reputation on FTE.mechmagcn has a very good reputation on FTE.
My 53 is no help because it is darksided with electric speedo, but the 53 parts truck still has the cable in place. As far as I can tell, it comes thru the firewall several inches above the steering column, between the column and inner fender, between the brake and clutch pedals and from there I'm not sure because it seems to loop under the trans. This could be related to the PO installed 289 and 4 speed
Speedometer cable 3 gear manual transmission Andy_F100 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-14-2015 10:29 AM
'94 F-150 speedometer doesn't work 88n94 1987 - 1996 F150 & Larger F-Series Trucks 3 10-14-2014 10:56 PM
71 f250 speedometer issue JacobRM 1967 - 1972 F-100 & Larger F-Series Trucks 19 06-03-2014 07:35 PM
Speedometer not working - automatic 2wd F-350 diesel astembridge 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 05-30-2013 08:56 PM
Speedometer glass seal/gasket? rwkinch 1961 - 1966 F-100 & Larger F-Series Trucks 1 11-28-2012 07:59 PM
Tags
05, 1948, 1966, 2000, 4700, cable, escape, f100, ford, international, routing, speedo, speedometer, taurus, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
