Figuring out my 51' F1
Old 07-04-2011, 04:33 PM
F1Jayhawk's Avatar
F1Jayhawk
F1Jayhawk is offline
Here's a pic of the dash. Can someone tell me the story behind the "Super". Maybe I'm just bad at searching on the computer, but I can't find anything.
Old 07-04-2011, 04:36 PM
F1Jayhawk's Avatar
F1Jayhawk
Also, what exactly is this?
<img src="http://i805.photobucket.com/albums/yy333/TheMiracles79/underglove.jpg">
Finally, how difficult is it going to be for me to remove the cab and bed? What type of equipment am I needing to do this? Thanks for all the help FTE!!
<img src="http://i805.photobucket.com/albums/yy333/TheMiracles79/truck.jpg">
Old 07-04-2011, 05:21 PM
Old F1's Avatar
Old F1
Old F1 is offline
1. I think it’s off something else, the PO stuck it there.
2. Some kind of hot water heater, looks like defroster hose vents on the top, its not a magic air.
3. They are really not that heavy, three friends with strong backs and weak minds.
Old 07-04-2011, 05:48 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,448 Likes on 1,396 Posts
The "super" is previous owner installed. Non-stock. That's why you couldn't find any reference to it. Could be from a Buick.
Your center picture is your heater box, with defroster ducts on top.
It's not hard to remove the bed and cab. It's just bolts to remove, and then 'lift, and separate' as Jane Russell used to say. ;p
Old 07-05-2011, 11:21 AM
old_dan's Avatar
old_dan
old_dan is offline
Get about 4 friends to stop by after you get everything unhooked. There is a pretty good write-up in the Dennis Carpenter catalog on how to replace the cab mounting pads and bushings in the rear swing-arms. Here's the link...it is a big .pdf file, so depending on your internet connection speed, it could take a couple of minutes to load.
http://www.dennis-carpenter.com/pdf/48-56_2010.pdf
The bed is easier and lighter than the cab, but you can use the same friends to help you lift that off as well.
Old 07-05-2011, 01:44 PM
Pa&Nic51's Avatar
Pa&Nic51
Pa&Nic51 is offline
I used my engine hoist with a wooden beam lashed to the top the arm. Lifted it up and rolled it out of the way. I also built a cab rotissiere with wheels that is great. Cab rotates 360 degrees and onle cost $100.
davewild
349
08-30-2020 10:17 AM
puddle
51
02-26-2017 01:35 PM
mbarrad
24
04-27-2016 01:40 PM
1andonlywhitie
07-16-2011 03:25 PM
Milwaukee1979F150
01-04-2010 05:28 PM
Quick Reply: Figuring out my 51' F1
