Fuel gauge reads backwards - Ford Truck Enthusiasts Forums
Old 07-04-2011, 05:26 PM
Terpfords's Avatar
Terpfords Terpfords is offline
Terpfords is starting off with a positive reputation.
I've had this nagging problem since it put the truck back on the road. My original tank rusted out so I replaced the tank, pickup w/pump and sending unit.
I read on a past post to read the resistance of the sending unit so I dropped the tank last weekend and the resistance was 15 ohms almost empty.
Any thoughts?
Old 07-04-2011, 05:34 PM
Sw1tchfoot Sw1tchfoot is offline
Sw1tchfoot is gaining momentum as a positive member of FTE.Sw1tchfoot is gaining momentum as a positive member of FTE.
I have read that the newer trucks read backwards compared to the 1980-1986 trucks.
Old 07-04-2011, 05:38 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
What is the Ford engineering number on the sending unit?
Also what year is your truck?
It sounds like you mis-matched the sending unit with the wrong year range.
Old 07-04-2011, 05:49 PM
Quote:
You got the right idea, but not quite right.
1980-1986: The Fuel gauge reads full with the least resistance.
1987-up: The fuel gauge reads full with the most resistance..
Old 07-04-2011, 05:51 PM
Terpfords's Avatar
The tank assembly came from MTS.
And to add, I bought a tach gauge assembly from a member off the boards.
I have a 85 F150 FI302 that has a single in the tank pump.
Old 07-04-2011, 06:16 PM
Terpfords's Avatar
When I dropped the tank last weekend it was almost empty, but the gauge read almost full and was 15 ohms of resistance.
Gauges don't interchange between models of trucks do they?
Old 07-04-2011, 06:30 PM
I would say your sending unit is the culprit, and they gave you the wrong one for your application.
1980-1986 sending units should read between 80-10 ohms resistance. 10 Ohms being Full, 80 ohms being empty.
1987-Up sending units read the exact opposite. 165 ohms full, 10 ohms empty.
No the later 1987-up gauges are different.
Old 07-04-2011, 07:42 PM
Terpfords's Avatar
Great info! Then my next step will be to call MTS.
In cab fuel tank sending unit? Pitcrw6 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-02-2014 05:36 PM
Fuel Gauge Sending Unit Resistance Hopsing69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 03-16-2014 10:38 PM
fuel sending unit conundrum lonewolfone Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 10-09-2013 07:44 PM
Fuel gage testing jschluter 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-29-2012 12:40 PM
Fuel Sending Unit lrhill Electrical Systems/Wiring 7 12-02-2003 07:00 PM
Tags
97, aftermarket, backwards, e350, f150, ford, fuel, full, gauge, guage, motorhome, mts, reading, reads, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
