2006 6.0 engine miss ? - Ford Truck Enthusiasts Forums
Old 07-04-2011, 11:46 AM
hhh100 hhh100 is offline
hhh100 is starting off with a positive reputation.
one owner 2006 = 6.0 f350 2wd dually , 80,000 miles pure stock , starts idles fine , raise rpm above fast idle has bad miss /no power , ran great till it started acting like this today..............?
Old 07-04-2011, 12:03 PM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Have you pulled the codes? You can still have codes set even if your wrench (CEL) light is NOT on.
Sounds like injectors to me. Or FICM. Look here: http://www.ford-trucks.com/forums/89...procedure.html
2006 ipr problem? yak 6.0L Power Stroke Diesel 22 03-07-2015 03:23 PM
Miss at Speed mikemartinsr 6.0L Power Stroke Diesel 1 01-01-2015 03:08 PM
Carrier bearing shim newbie2006 6.0L Power Stroke Diesel 17 10-28-2013 03:53 PM
2006 6.0 no idle and no throttle studanman 6.0L Power Stroke Diesel 18 10-06-2013 07:38 PM
06 F250 6.0L . . . .HELP! 2006 F250 6.0L Power Stroke Diesel 15 06-03-2012 11:53 AM
Tags
03, 06, 2005, 2006, 60, diesel, engine, excursion, f250, f350, ford, mis, miss, misses, missing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
