2001 F250 Brake Fluid type? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-04-2011, 12:10 PM
SD Rick SD Rick is offline
SD Rick is starting off with a positive reputation.
Hi All,
I'm in the process of replacing two rear calipers/pads and rotors on my 2001 F-250 Superduty pickup truck.
Rear calipers must have been hanging up ,and it wore the inside pad of the driver and pass side ,so although all the brakes visually looked good,the rear inners were worn to the point of taking out the rotors,and then a piston on the driver side ,once it wore to that point. Only heard the grinding about one day before it eventually failed?
Anyhow, I noticed that the brake fluid seems to have a greenish tint to it,at least that what is draining out once the calipers were removed.
I don't have the TSM for the truck,and was wondering if this brake fluid is special,or is a basic DOT 3 fluid OK?
Thanks in advance!
Rick
Old 07-04-2011, 01:17 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Yes, I believe DOT3 is the proper fluid.
Old 07-04-2011, 07:51 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Greenish fluid means it's time to flush the reservoir and the lines to get fresh fluid in there. DOT 3 is what's called for.
Old 07-04-2011, 10:12 PM
Thanks guys.
I will definately be flushing the system real good.
Rick
F350 Front Brake chatter f350nick 1987 - 1996 F150 & Larger F-Series Trucks 0 08-22-2016 07:09 PM
superduty rear disc brakes frankiethethumper 1999 to 2016 Super Duty 11 04-13-2014 07:19 PM
rear brake hose or caliper? mikeismadness 1999 to 2016 Super Duty 5 10-25-2012 09:56 AM
Mugly is down! Quick444 1999 - 2003 7.3L Power Stroke Diesel 10 08-10-2010 08:26 PM
rear brakes dragging hotwtr 1999 - 2003 7.3L Power Stroke Diesel 7 11-17-2009 07:58 PM
Tags
1997, 2001, 73, brake, brakes, break, change, diesel, f150, f250, f350, fluid, ford, kind, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
