Boiling over and no clue why??? 1995 F150 V8 - Ford Truck Enthusiasts Forums
Old 07-04-2011, 09:11 AM
nottelybill nottelybill is offline
nottelybill is starting off with a positive reputation.
Question Boiling over and no clue why??? 1995 F150 V8
1995 F150 V8 - My truck was getting exceedingly hot so I put a new thermostat in it. It still got to boiling. So I checked to see if I had put it in backwards-NO. So then I put the thermostat in some boiling water to see if it would open and yes it did. So now what do I do. This truck has never even hinted at getting hot. Water seems to be flowing ok but not sure exactly how to check that. HELP
Old 07-04-2011, 09:20 AM
octaneforce's Avatar
octaneforce octaneforce is offline
octaneforce is starting off with a positive reputation.
is it just water in the system? plain water has a much lower boiling point than coolant.
Old 07-04-2011, 09:40 AM
rquinlans rquinlans is offline
rquinlans is starting off with a positive reputation.
water pump
Old 07-04-2011, 10:16 AM
chris11376 chris11376 is offline
chris11376 is starting off with a positive reputation.
sounds like water pump. does the heater blow out hot air? most times heat wont blow hot if water is not circulating. whats the temp gauge read?
it seems the bottom of radiator is clogged. water will not run out of little drain plug. what's the change radiator flush would clear this? Must be rust.
Old 07-04-2011, 10:23 AM
easy way to tell unhook the radiator hose that goes from the bottom hose to the engine(do this with a cold engine) unhook from the engine, not the radiator or you're wasting your time hold it up so you dont lose all your water and have someone star the engine. if its not stopped up water will come out. If you get no water unhook hose from water pump to radiator, if no water flow or very little, pump is bad. if you get a real good flow then radiator is clogged
Old 07-04-2011, 11:31 AM
never had a water pump that didn't make noise when it went bad.
Thanks will try that test.
Old 07-04-2011, 01:07 PM
Bankrupter Bankrupter is offline
Bankrupter is gaining momentum as a positive member of FTE.
I never had one that did make noise. But I have only lost 2 GM pumps. GL with it~
Old 07-04-2011, 02:11 PM
deeznuts822's Avatar
deeznuts822 deeznuts822 is offline
deeznuts822 is starting off with a positive reputation.
Did you pull a heater hose from the core to purge the air? I put in 2 stat brand thermostats and they all failed. Went to ford and problem was gone. By chance do you have a collapsed hose when it gets hot? Your water pump turns off the belt so i would guess if its turning its pumping some type of water...
truck instantly gets hot then Lumpy78 1967 - 1972 F-100 & Larger F-Series Trucks 16 10-11-2014 12:04 AM
Overheating six MFJ 1987 - 1996 F150 & Larger F-Series Trucks 29 09-08-2014 01:46 AM
themostat issues sixshootingexp 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-02-2012 10:44 AM
95 350 overheating problems raceman308 1987 - 1996 F150 & Larger F-Series Trucks 10 06-20-2011 04:34 PM
Thermostat Blackwaterforge Ford Inline Six, 200, 250, 4.9L / 300 15 07-14-2010 11:04 AM
Tags
1995, 460, 95, antifreeze, boil, boiling, boils, bubling, engine, f150, f250, ford, point, radiator, v8, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
