A/C wont change from defrost - Ford Truck Enthusiasts Forums
Old 07-03-2011, 03:23 PM
jjdoyle jjdoyle is offline
jjdoyle is starting off with a positive reputation.
I have a 2005 ford excursion limited, 4X4 diesel. When I turn the A/C on it will only blow through the defrost vents (windshield and front windows). I push the other buttons to change the flow and get no response. I hear there is a vacuum actuater under the dash, any ideas
Old 07-03-2011, 11:08 PM
Swagtastic Swagtastic is offline
Swagtastic is starting off with a positive reputation.
You have a vacuum leak (95% likely) or a bad air blender (5% likely) Most common spots for vacuum leaks #1 somewhere in the 4WD lines. #2 whatever lines are exposed to the most heat or vibration. That may sound like generic advice but that's how it is, vacuum leaks are tied for the most irratating problem to figure out, oh yeah, electrical gremlins are the other tough one.
Old 07-03-2011, 11:23 PM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
I'd recommend checking out the 8th item on THIS PAGE for maintenance, and then getting some new lines for your ESOF system.
Old 07-04-2011, 10:07 PM
ScottyDsntKnow ScottyDsntKnow is offline
ScottyDsntKnow is gaining momentum as a positive member of FTE.ScottyDsntKnow is gaining momentum as a positive member of FTE.
This just happened on my Expy, if the Excursion is at all similar, there should be two lines going into the firewall right behind the battery. On my Expy, one of them was loose and actually open to air creating the exact condition you describe.
Old 07-05-2011, 10:34 PM
EX40 EX40 is offline
EX40 is starting off with a positive reputation.
I had this same problem on a '94 Mustang. I'd check the lines under hood 1st.
Old 07-06-2011, 03:19 AM
offroad_x's Avatar
offroad_x offroad_x is offline
offroad_x is gaining momentum as a positive member of FTE.
This has happened to me a couple of times. It was always a leak in the 4wd lines or hubs. To test the hubs just plug the vacuum lines going to the hubs (a golf tee works nicely) and see if your a/c vents start working.
A/C KEEPS SWITCHING TO DEFROST ON ITS OWN??? jstihl 1999 - 2003 7.3L Power Stroke Diesel 17 01-18-2016 09:25 AM
A/C max blows out defrost. mshargrave23 1999 - 2003 7.3L Power Stroke Diesel 12 09-15-2013 12:02 PM
AC blows through defrost only 99-exp 5.4 99exp4wd5.4l 1997-2006 Expedition & Navigator 5 06-16-2012 04:52 AM
A/C suddenly changed to blowing though defrost RollTideRoll 1999 to 2016 Super Duty 8 05-22-2011 03:33 PM
Surging idle with a.c. and defrost on. dep295 1987 - 1996 F150 & Larger F-Series Trucks 5 08-06-2008 06:11 PM
Tags
02, 73, ac, blow, common, defrost, dont, duty, excursion, f150, ford, leaks, super, vacum, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
