Clutch Bleed nightmare
I replaced my clutch master cylinder, due to a broke clutch rod.
I did not pull the slave cylinder, so I did not bench bleed it.
After I installed the new master, I have no pedal pressure at all, it goes straight to the floor, and stays there. I bled it for a good 3 hours last night and got a pretty steady stream after tipping the MC forward and re installing then bleeding, but still no pressure.
I let it gravity bleed over night, But I still dont think I will still have pressure, what could this be?
