MPG Gauge - Ford Truck Enthusiasts Forums
MPG Gauge
Old 07-03-2011, 01:34 PM
Bobjones294 Bobjones294 is offline
Bobjones294 is starting off with a positive reputation.
MPG Gauge
I have a 2000 Ford E350 with a V10. I am looking at adding a fuel monitor. I've heard they are easy to put in by just plugging into the OBD2 connector. By past experiences can someone recommend a name brand or model.
Regards Bobjones
Old 07-04-2011, 02:39 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
MPG gauges that plug into the lie-o-meter, err I mean computer, are notoriously generous on their readings. In stead consider a fuel flow meter. I got the idea from mythbusters. In stead of calculating mpg, it measures GPM (gallons per min). While no, it wont tell you how many MPG you are getting, but it gives a 100% accurate relative reading on how much fuel is being used. And some quick math will give you MPG..
At 60MPH: GPM = MPG
Old 07-05-2011, 12:50 AM
Kramer73's Avatar
Kramer73 Kramer73 is offline
Kramer73 is gaining momentum as a positive member of FTE.Kramer73 is gaining momentum as a positive member of FTE.
Hi Trey
I have never heard of such a device, are they readily available or do you have to make one
Old 07-05-2011, 12:54 AM
A/Ox4's Avatar
9 ECHO 1
I've never seen one is a normal auto gauge fashion. (ie, autometer, issopro, etc.) However, you can order them or get them at lowes. I've even seen some with digital readouts, which could be installed somewhere in the dash.
Its definitely something you would have to custom make. I've never seen one purpose built for measuring fuel flow to measure MPG.
Old 07-05-2011, 06:30 AM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
This is just a question, but wouldn't a vacuum gauge be the most 'accurate' fuel-being-used-at-the-current-time meter?
Unfortunately, Trey is correct (although the new 2011 F150 dash display meters seem to be a lot closer than previous versions) about the dash or OBDII meters (including my Gryphon/Edge CTS on my 2009 F150).
Only way to be exact is to maintain a mileage and fuel used log (kind of driving by looking in the rear view mirror). I keep mine on Fuelly.com (as well as a spreadsheet).
determining truck build date Jaime74656 1999 - 2003 7.3L Power Stroke Diesel 1 12-25-2015 08:53 AM
Topless wpnaes Excursion - King of SUVs 26 07-15-2013 09:18 PM
Where is serial # on 1946 or 47 half ton pick up? Trulyvintage 1947 and Older Ford Trucks 3 05-20-2011 10:40 AM
I need HiSPL Testing..... 3 08-19-2009 05:52 PM
how do I know if I have a 400 Ford_Six 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 11-13-2002 08:45 PM
Tags
accurate, automotive, computer, e350, f150, f250, flow, ford, fuel, gauge, gpm, meter, mpg, plug, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
