help!!!
help!!!
ok made a mistake. on the drivers side valve cover there is a air hose the goes from intake to top of the valve cover what is that? i just tried to pop it off and the plastic peice connetting hose to vlve cover broke and i and little peice fell into the hole. So i guess i am needing to take valve cover off now to find the piece. what is the plastic part call that i am needing. Oh it is the v10. Thanks
it is real tiny so you think it would be ok to run the truck that way, i just did not wont it going into the valve spring. what i might do if that is the case is run it then go change oil today.
I think you will be ok. Just go to the auto parts store and explain the piece to them and they should have it in stock or you may need to order it.
Crank case ventaliation is all is suppose to do.
Inside the valve cover they make a small piece of steel to semi cover the opening so oil does not splash out and then get sucked up the rubber hose.
kameleon
06-21-2002 09:56 PM
