How to change tie rods (w/ pics!) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-22-2014, 07:47 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
Old 07-03-2011, 09:16 AM
martin123456789 martin123456789 is offline
martin123456789 is gaining momentum as a positive member of FTE.martin123456789 is gaining momentum as a positive member of FTE.
I noticed this:
And it also smelled like burned oil, to my surprise it turned out to be this:
Yes, one of the boots busted.
And upon, jacking up the vehicle there seemed to be a little loose in that tie rod when pushing/pulling the passenger side tire.
Just to be safe, both tie rods will be changed, the other one looks like:
Notice how cracked/dry the rubber is? I will start spraying these(and the other rubber boots) with silicon at every oil change from now on.
Purchase some new tie rods:
Lift up vehicle using notches on the radius arms, and position some axle stands, safety first.
Before doing anything, measure everything!
Counting the number of turns when taking off a tie rod end is not going to work, one of them turns in the wrong way. Measure the distance instead, 1 turn will make a noticeable distance difference.
I would also advice on measuring the total length of the tie rod bar, this should allow you to put it back pretty much like it was.
Now spray plenty of this stuff:
Try to drown these:
You might want to secure the steering wheel with a seat belt, just in case.
Now, undo the bolt on the passenger side, use a puller and/or a hammer to separate them. Then unbolt the driver side, same strategy. (Sorry no pictures)
Now that you have tie rod bar in your hands, put it into a vice to undo one end.
Inspect, mine had this:
Spray more of that stuff:
Now with the adjusters loose (take that bolt out!), try to pry this a little, and use a pipe wrench to unscrew the tie rod. (If you feel like counting the number of turns be my guest, good luck)
Now put the new end on, and turn the same exact number of turns, or better yet just measure the gap (this is assuming the new part is exactly like the old part):
Once both ends are done, re-installation is easy.
Just bolt it up, I think the torque specs are 85lb-ft for the tie rod ends and 41lb-ft for the adjusters but double check this, I could be wrong.
Measure the distance between the front tires in the front and in the back, it should be about the same.
Now it's time to get an alignment and you're done!
Old 07-03-2011, 10:03 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
Excellent thread... pics are perfect. Rep's given!
Old 07-03-2011, 10:25 AM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
Nice job...
Old 07-03-2011, 10:29 AM
jd58980's Avatar
jd58980 jd58980 is offline
jd58980 has a good reputation on FTE.jd58980 has a good reputation on FTE.jd58980 has a good reputation on FTE.
Nice Write up..Reps given
Old 07-03-2011, 10:30 AM
sddesigns's Avatar
sddesigns sddesigns is offline
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
Great Job and nice picture progress!
reps given!
Old 07-03-2011, 03:29 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
sweet write up nice pics
what year is your truck my tie rods alittle diff but thats ok still about the same work
the only boot thats leaking is the Tie rod at the steering box
I was going to count the turns and also try and mark its position on the steering linkage
funny how 1-2 turns one way or another can throw alignment off
funny I measured the distance same way you did on my car and with some driveing and adjustment I got it right on It was easy but also only had one tire wearing funny so I knew I had to adjust that one by the time I had it going straight down the road the steeringwheel ended up centered perfict
Old 07-03-2011, 03:35 PM
I have a 2005 F250, this should apply till 07.
However, it's likely to be very similar for other years.
Old 07-03-2011, 03:36 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Nice Write-Up! Reps sent!
Old 07-03-2011, 05:50 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
Another nice write up with pics! Thanks!
I tried to rep ya but I just repped ya in your heated seat thread so I gotta spread it around first.
Old 07-04-2011, 02:11 AM
Fallguy2004's Avatar
Fallguy2004 Fallguy2004 is offline
Fallguy2004 is starting off with a positive reputation.
Great write up. Question though, your truck appears to not have a steering stabilizer. Also noticed my truck doesn't have one while doing my front end.
Whats the deal here?
Old 07-04-2011, 07:42 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Great job and write up. I have one that is going to need to be changed out soon myself.
Old 07-04-2011, 03:36 PM
Here's a better angle, should be easier to see like this.
*Notice the valve on the oil pan
Old 07-04-2011, 03:41 PM
Quote:
Make sure the rubber is still good on the other one.
And if the other one goes right after, you have pay the shipping fee, tear it down again & get an alignment.
Might as well do both?
Btw, total cost was 100$ per tie rod & 40$ shipping. -> 240$
(No alignment was done yet..)
Old 07-04-2011, 03:44 PM
senix's Avatar
I will just do both at the same time. I had one bend on me slightly. Still within specs for now but I know it is not wearing evenly
Old 12-14-2011, 05:25 PM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
HI, I am changing the Right one with Moog, mine is a 2006 and looks pretty well the same, the left looks OK but maybe I should do both.
What is the Moog number for the Left side (driver), I could not get a number. They want $184.00 for one here.
I got the Right one replaced 16 month ago with a ford Motorcrap, 11,000 miles on it and it's got a gook half inch play now, what a crarp. I also replaced the left hand ball joint, the upper one had quite a bit of play, may be it scrapped the tie rod??
THERMOSTAT REMOVAL with PICS BLADE35 6.0L Power Stroke Diesel 36 01-08-2015 05:50 PM
Look what I did at work today... ReBilld 1994.5 - 1997 7.3L Power Stroke Diesel 51 07-14-2012 07:39 PM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 09:46 PM
Now that is some SERIOUS flex! With some mud in the mix.. PICS... YellowSled Excursion - King of SUVs 15 10-03-2010 01:20 PM
2010 FTE FAT FENDERED MOB Round ONE poll Greywolf General Automotive Discussion 78 02-28-2010 10:00 PM
Tags
1997, 73l, driver, duty, ends, f350, ford, powerstroke, replace, replacing, rod, rods, side, super, tie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
