1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-22-2014, 06:47 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
How to change tie rods (w/ pics!)
Old 12-14-2011, 04:47 PM
kidoo's Avatar
kidoo
kidoo is offline
Discount Car Parts Stuff - Car Accessories & Truck Accessories - Cheap Auto Parts - Car Cover - Floor Mats - Cargo Liner - 2006 Ford F-350 Super Duty Tie Rod End Stock Replacement
On that Web Site, they show one tie rod end
MOES80755 at $93.21 for a Ford F350, 2005 to 2009, 4WD, all engines
One MOES80754, 2005 to 2009, F350, 4WD, all engines: at $138.85
Which one is for my truck? I have a 350, Lariat, 4WD, 6.0, diesel.
Old 05-21-2013, 02:56 PM
AlbyVA's Avatar
AlbyVA
AlbyVA is offline
I need to do this with my 2008 F250. Do this pics and tips also apply?
Old 05-21-2013, 03:01 PM
sammie0126's Avatar
sammie0126
sammie0126 is offline
Well done write up!
Old 05-21-2013, 10:02 PM
bthr22's Avatar
bthr22
bthr22 is offline
A set of digital/analog calipers would be very handy for measuring the distance between the tie rod and the sleeve. Probably with more accuracy than a ruler too.
Old 05-22-2013, 05:40 AM
AlbyVA's Avatar
AlbyVA
AlbyVA is offline
I was thinking the same thing and lucky for me, I do have a pair of
digital calipers.
Old 05-24-2013, 07:05 AM
AlbyVA's Avatar
AlbyVA
AlbyVA is offline
My order has been placed for both Driver and Passenger Tie Rod Ends.
Part No: Moog ES80754 / ES80755
Old 05-24-2013, 08:42 AM
99F-350CrewCab's Avatar
99F-350CrewCab
99F-350CrewCab is offline
You can get pretty close with the alignment by using a tape measure and measuring the distance from tire to tire. Take a measurement in the front side of the tires, and then the rear side of the tires and compare. I'd still have it checked by a shop after, but the tape measure is a good way to check. Just measuring the gap on the parts assumes that the new part is manufactured exactly the same as the old part and that everything went back together exactly like it was. The real thing you are trying to check is if the front tires are parallel. Easiest way to do that is to measure them.
Old 05-24-2013, 09:05 AM
AlbyVA's Avatar
AlbyVA
AlbyVA is offline
I know my wheels are already "way" out of alignment. For me, almost will
be good enough, cause I plan on taking it to the shop once I'm done for a
proper wheel alignment.
Old 05-24-2013, 09:17 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
Better to put center line on each tire tread. measure across midway up. Adj to get the same width with new parts...Or with same lines adj to get aprox 1/16 tow in. Smaller in front of tire. See specs for exact amount..Spin tire to put center line on it...
Old 02-14-2015, 09:21 AM
jtug69's Avatar
jtug69
jtug69 is offline
03 f250 6.0L
Originally Posted by martin123456789
Make sure the rubber is still good on the other one.
And if the other one goes right after, you have pay the shipping fee, tear it down again & get an alignment.
Might as well do both?
Btw, total cost was 100$ per tie rod & 40$ shipping. -> 240$
(No alignment was done yet..)
Have an 03 f250 6.0L and it doesn't have a steering stabilizer, should it have one? And I got moog tie rods and sleeve for $120. Outer one was $72 on ebay free shipping
Old 02-15-2015, 06:53 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
Should you have one... Maybe maybe not. If all is well you could do without. If you want one on there go for it..They usually cure problems. If you have no shake or shimmy you prob don't need it. I could take mine off I don't think it would matter but it had one when I bought it.
Dick
Old 02-15-2015, 07:57 AM
jtug69's Avatar
jtug69
jtug69 is offline
03 f250 6.0L
Advance Auto says DS1438
  #28
Old 07-02-2020, 05:37 PM
Malimakamae's Avatar
Malimakamae
Malimakamae is offline
How long did it take to change them out?
JustinP
74
04-15-2017 08:40 AM
Sarah021
06-29-2013 04:29 PM
jchosler
15
10-26-2011 04:53 PM
dclack
08-02-2011 01:07 PM
akforceten
12-08-2010 08:00 PM
Quick Reply: How to change tie rods (w/ pics!)
